  1. Hi, dear all.
    ---> http://kijio-subtitle-editor.software.informer.com/0.6/
    Kijio is a new kind of subtitle editing software, where instead of just textboxes, you have a full visual control of the subtitles on a timeline.
    Kijio Subtitle Editor also allows you to translate your subtitles over 56 languages, which might help you with the translation if you are not good with the base language. This makes editing subtitles a matter of a few clicks.
    Best regards.
    devil (johner)
    Very buggy software....the installation didn't create a shortcut so you must go to the programs folders and find kijio.exe.
    And then after loaded a srt and video:
    THe preview didn't work that well(just audio works ok) and when I try access any settings it shows an error...
    But added a mirror to kijio...note that the last version is from 2011....
  4. Hi, Baldrick!
    Pity that the program do not work as it should be. Maybe the author's program could fix some bugs or something?
    Or release a newer version too?
    I have not tested yet here. But, at first look, such program remind me AHD Subtitles Maker in features and its way of timing the subtitles.
    Thanks for posting about the program & it's issues!
    Best regards.
    devil (johner)
