I'm looking for a starting point to resolve a DVD authoring problem.
Here's what I'm doing:
- I have many commercial VHS tapes that I want to convert to DVDs before my VCR dies. For most of them, I play them into a capture device to digitize and then use DVD Styler to convert and burn them to DVD. This works well.
- Since this is time consuming, I "cheated a bit". For some, I've downloaded a copy from the internet. (I justify that since I have purchased the VHS tape). I then use DVD Styler to convert and burn to a DVD.
My Problem:
For some (but not all) downloaded videos, the resulting DVD will freeze every 3 to 10 minutes. It will only restart if I press "skip" then "play".
In part, here's what I have done:
- Used MediaInfo to look at the downloaded videos. There is no total commonality but most are MPEG-4 (Base Media) with an AVC video stream.
- I've converted some of the downloaded videos that originally failed to MPEG-2, then used DVD Flick to convert them to DVD and used CD BurnerXP to burn the DVD.
- Some DVDs are OK others still freeze. Again, I can't find any commonality in the file format for the failures.
I'm using Memorex DVD-Rs from a 100 spindle. I've used about 80 of these DVDs on the same DVD burner for other projects and not had a single failure.
My default is to use to digitize the original VHS tape but I'd like to find the problem (for my education if nothing else).
Does anyone have a suggestion where I might look for the problem?
Just a guess....lower the bit rate quality setting
Old 4:3 VHS video will take up less space
If you are using max bit rate to fill the disc
You have a bit rate that is too high
keep VHS conversion keep bit rate below 4k, 2500>3000 should work well for what you are doing
I agree use Avs2dvd, -
I understand and my conscience is bothering me a bit. However, I don't see the difference between digitizing the VHS tape which I have purchased and downloading a video that someone else has produced. In either case, I get a copy of the movie that I have already purchased. As I understand it, in purchasing the VHS tape I have paid a royalty to the originator. It seems a bit overkill to buy the DVD too and end up paying the royalty twice. In the end, I'll only be using one copy.
To sooth my conscience, I'm thinking about the old Borland Quattro Pro licence. That licence allowed you to copy the program to as many devices as you wanted as long as you were only using one at a time. They equated it to buying a book and loaning to someone else to read.
Am I rationalizing too much?
BTW I've downloaded AVS2DVD and will try it.
Thank-you -
i can understand how you feel
but you'll get no sympathy from the moderators, they are bound by rules, they can not change
its a subject best left unspoken -
Well the issue about the download is quite straight-forward(in my eyes). The person who has shared that has violated the copyright since the encode is no longer for his own use.
By downloading it, you encourage more violation.
Strictly speaking, ownership of the VHS does not allow you to do anything but play it. That is your licence. But there exists this convention (unwritten ?) of 'fair-use' which the site supports of format-shifting/backup. As long as you do not share and simply do for your own use.
And the site can not do anything else to help else it is seen to encourage copyright violation and could get in to serious trouble. -
OK. I get the message.
I'll give up on the downloaded videos and digitize my VHS tapes. It will take more time but at least that should conform the the fair use view. It will probably solve my DVD burning issue too.
Sorry to have raised such a controversial issue.
Authored DVD remote control navigation problem
By dilophosaurus65 in forum Authoring (DVD)Replies: 8Last Post: 10th Dec 2015, 14:42 -
Authored Video DVD won't play on a DVD Player
By Inlesco in forum Authoring (DVD)Replies: 4Last Post: 8th Feb 2015, 04:26 -
DVD player locks up when I try to play disk with menu authored by DVD Flick
By aprete in forum Authoring (DVD)Replies: 2Last Post: 19th Jun 2013, 21:19 -
Incorrect language copied while playing authored DVD
By BRFan in forum Authoring (DVD)Replies: 5Last Post: 26th Dec 2012, 08:00 -
Problem Playing Authored/Burned Dvd on DVD Player
By djgazzabhoy in forum Video ConversionReplies: 10Last Post: 24th Nov 2011, 14:15
