I noticed that when I was capturing my screen, there was an option to select the estimated file size and change the bitrate, however, I selected edit which then opened the "New Project" gui, cropped and trimmed it, but file size was around 1.8gb, and I ideally want around 1gb, with no options anywhere to reduce the video bitrate. I can only see a Quality setting which offers Good/High/Highest, even dropping the frame rate from 30 to 25 doesn't seem to have reduced the filesize.
I want to maintain the 720p res, but just wanted to reduce the bitrate, but see no way of doing this.. any advice??
Cheers
Only bitrate and "constant" quality settings will reduce the file size. So if Good wont get you smaller size can't do you do much.
You could just shrink your captures with something else like vidcoder where you can set the output file size under settings.
Or try another screen capture software like Open Broadcaster Software, NCH Debut or Icecream Screen Recorder. -
Cheers for that.. having just bought Movavi, I was hoping to do all with it, but will look at the other options, as I can always request a refund.
It seems I can modify the bitrate when the screen is captured, but if I want to do additional editing, when I then try to save it as a media file, I dont get bitrate options and can end up with a much larger file. -
I use Replay Video Capture
I can set Bit rate
I prefer to capture on the highest quality I can
File size can be reduced later, when changing formats or archiving the video -
Movavi Screen Capture
By henry4956 in forum Video ConversionReplies: 14Last Post: 25th Nov 2016, 12:40 -
How to reduce mkv file size
By onlygk in forum Video ConversionReplies: 12Last Post: 25th Jul 2016, 22:36 -
[Q] How to significantly reduce file size
By edd1234 in forum Blu-ray RippingReplies: 31Last Post: 10th Jun 2015, 19:13 -
Screen capture with Movavi looks way too bright
By NerdDoc in forum Capturing and VCRReplies: 4Last Post: 24th May 2014, 13:24 -
Reduce file size of sub/idx?
By thinredline in forum SubtitleReplies: 6Last Post: 2nd Feb 2014, 12:01
