I'm trying to properly burn a DVD movie that I've customized using ImgBurn. The disc works, but it takes a very long time to load compared to the other ones I've made that are similar. When I pop it in the player, I have to wait a full minute and a half, and listen to lots of scratchy disc-searching noises before the movie finally plays.
Is there something I can edit, perhaps using PgcEdit, so that the disc plays right away like the other ones I've made? I've wasted four double-layer DVDs trying to figure this one out on my own. The same thing keeps happening.
One thing I can say is that the only difference between this one and the other ones I've made is that with the other ones, I used PgcEdit to switch one of the subtitle tracks on by default.
Results 1 to 16 of 16
The op meant he burned the customized dvd with imgburn,most likely the issue is the dvds you are using to burn,if they aren't verbatim dual layer made in Singapore then that's the issue cause most all other dual layers are crap.
Perhaps you have blanked a lot of short clips (logos, trailers...) with VobBlanker. You cannot see them any more, but the original titlesets where they were located are still visited, and a short black clip is still played. That means that the player has to go to several VTSs and return to the VMGM several times. That may be very slow and cause a lot of useless moves of the head.
To avoid that, you can use PgcEdit's PGC -> Jump to PGC Upon DVD Insert. It modified the VM commands so that the player will jump directly to the PGC you want to play first (menu or main movie). That will reduce the number of head moves, and play the first PGC with meaningful content (almost) immediately.r0lZ - PgcEdit homepage Hosted by VideoHelp (Thanks Baldrick)
- BD3D2MK3D A tool to convert 3D BD to 3D SBS/T&B/FS MKV -
I have questions about the guide at http://www.digital-digest.com/~blutach/Jump2PGC/Jump2PGC_guide.html.
Step 9 says "Now start the trace again by pressing the load/eject button and Run."
Nothing seems to happen, but maybe that's just because whatever it did was instantaneous.
Step 9 also says "Tip: It's usually a good idea to select your audio and subtitle preferences, even if it is just “no subtitles”, as some players do not like working with just the defaults."
How do I select my audio and subtitle preferences? There is only one of each, and I want the audio on, and the subtitles off.
Step 16 says "Press the Load/Eject button on the trace toolbar and run through the DVD step by step to ensure it starts where you wanted it to."
Nothing seems to happen when I press the Load/Eject button. Again, maybe it's just doing it instantly.
I'd be surprised if it were the discs because the results I'm getting are so consistent. For the three movies I'm working on, I've burned the one I'm having problems with four times, and the other two I've burned two times each. So I have four perfect discs from the other movies, and four problem discs with this one movie I've been describing. That having been said, some discs in the stack are duds, but when they don't work, I tend not to get past the burning stage. -
It seems that you have not understood how to use the trace. It is not sufficient to load the DVD, You must also run the trace.
Pressing the Load/Eject button resets the state of the trace to the default, as it is in a real player when you insert the DVD. The navigation pointer should return to the first pre-command of the First-Play PGC. The values of all GPRMs and SPRMs are also reset to their defaults. Of course, you can see the change only if you have run the trace previously (or selected manually a PGC in the left pane).
You must understand that running the trace simulates the playback of the DVD in a real player. The difference is that you can analyse and control exactly what's happening, step by step. You start the trace by opening it (from the Trace Menu). When the virtual player panel appears in the bottom right corner of the main window, press the "->>> Run" button to launch the trace. (You can also press "-> Step" or "->> Next PB" repetitively if you want to analyse all commands individually, but that's not necessary in this case.)
When the trace runs, the navigation begins, as it does in a real DVD, by executing the pre-commands of the First-Play PGC. Then, it continues to the various PGCs that are called before reaching the main menu. If the preview of the video is enabled, you may see the video clips that have been blanked by VobBlanker, and/or other clips that you have not blanked. Just ignore them by closing the Preview window. They are the clips of the PGCs we want to bypass by jumping directly to a more interesting PGC. If a menu pops up and you want to bypass it too, just select the button you would select in a real player to continue the trace. If the trace mode stops for any reason, press Run again to restart it.
During the trace, you should NEVER select manually another PGC in the left pane or another command in the right pane, as doing this will perturb the normal navigation. Use ONLY the commands in the virtual player panel and in the menu viewer to navigate through the DVD.
When you have reached the PGC you want to play first (let say it's the main menu, or the intro video of the main menu), place a pre/post breakpoint. That breakpoint will interrupt the trace automatically the next time that PGC is reached. Now, the preparation is finished, and the main job begins. Take care, the next trace is important because it will be recorded.
Restart the trace (with Load/Eject). The navigation should return to the first-play PGC and everything will reset, so that you can start again from scratch. Only the break point will remain. Press Run again and let the trace run. The values of the GPRMs and SPRMs are modified by the commands that are executed, and recorded by the trace. When the target PGC (the main menu) is reached, the trace will stop automatically, due to the break point, at the first pre-command of the PGC (and therefore before the playback of the menu video itself). Do NOT continue to trace.
Now, apply the Jump to PGC upon DVD Insert function. It will modify a few PGCs so that the navigation will go as rapidly as possible to the main menu, and it will restore the GPRMs and SPRMs to the value recorded during the trace, so that the player will continue from that point exactly in the same state as it was after the trace.
When done, I suggest to run the trace again, to verify that everything works fine. This time, rapidly after having launched the trace, the navigation should go to the main menu.
The optional step of selecting an audio and/or subtitle stream is useful only if you are not happy with the default streams selected automatically by the player. You don't need it.r0lZ - PgcEdit homepage Hosted by VideoHelp (Thanks Baldrick)
I did run the trace. I just wasn't sure if I did it right because I couldn't tell. Reading the guide again and reading what you say, I think I'm doing it right. It seems like you've sort of reiterated parts of the guide, correct?
Is there any way to check to make sure I've done things right before burning it to disc? I mean, besides hitting the eject and run buttons and plopping the video into a player? -
You mean how did I customize it? I used DVD Shrink to rip the main title only from the DVD, PgcDemux to demux it, MuxMan to mux it, and PgcEdit to change the subtitle colors.
Aaargh! Indeed, you should have answered hech54's question immediately. I would not have wasted my time.
So, you have only a single title, without menus, extras and so on on the DVD? In that case, it is absolutely useless to use Jump2PGC to skip useless PGCs, since there is only one PGC anyway.
And therefore, a good explanation is what johns0 suggested: bad discs. The problem can also be caused by a bad burner, or a bad DVD player, but anyway, it's an hardware problem, not related to the authoring of the DVD.r0lZ - PgcEdit homepage Hosted by VideoHelp (Thanks Baldrick)
Oh, maybe the problem is caused by protected cells in the beginning of the movie. (I don't think so, because dvdshrink should have refused to rip the movie in case of protected cells, but who knows?)
Open the ripped DVD in PgcEdit, select the movie PGC in the left pane, and use Info -> PGC. Copy the content of the dialog and paste it here.r0lZ - PgcEdit homepage Hosted by VideoHelp (Thanks Baldrick)
VTST 1 , 1 TTN 1 (2:04:46) Title 1 - Chapters: 54, Programs: 54, Cells: 54 ********** pre commands: ********** post commands: ********** cell commands: Playback time: 02:04:46.05 (at 30 fps) PG Playback mode: sequential PUOs: 0 (0x00000000) NextPGCN: 0 PrevPGCN: 0 GoUpPGCN: 0 PGC Still Time: 0 Audio stream 1 status: 0x00008000 (stream=0) Subpic stream 1 status: 0x80000000 (streams for 4:3=0, wide=0, letterbox=0, pan&scan=0) BOVs Chap. Prog. Cell Type Seam- Ang VOBU Cell Cell Playback End Entry First Last Last VOB Cell (PTT) Flags less Still Still Cmd. Time Time VOBU ILVU VOBU VOBU ID ID Joint Time # sector End Start End 0 1 1 1 2 no - no 0 0 00:00:20.25 00:00:20.25 0 0 5899 6020 1 1 0 2 2 2 8 yes - no 0 0 00:01:36.04 00:01:56.29 6021 0 38647 39090 1 2 0 3 3 3 8 yes - no 0 0 00:02:18.11 00:04:15.10 39091 0 103078 103496 1 3 0 4 4 4 8 yes - no 0 0 00:04:02.05 00:08:17.15 103497 0 211686 212065 1 4 0 5 5 5 8 yes - no 0 0 00:01:48.19 00:10:06.04 212066 0 257554 257737 1 5 0 6 6 6 8 yes - no 0 0 00:02:42.10 00:12:48.14 257738 0 329068 329418 1 6 0 7 7 7 8 yes - no 0 0 00:02:14.20 00:15:03.04 329419 0 391568 391828 1 7 0 8 8 8 8 yes - no 0 0 00:01:16.06 00:16:19.10 391829 0 426649 426978 1 8 0 9 9 9 8 yes - no 0 0 00:02:00.06 00:18:19.16 426979 0 471831 471972 1 9 0 10 10 10 8 yes - no 0 0 00:01:15.28 00:19:35.14 471973 0 502957 503124 1 10 0 11 11 11 8 yes - no 0 0 00:01:37.05 00:21:12.19 503125 0 545325 545586 1 11 0 12 12 12 8 yes - no 0 0 00:02:35.06 00:23:47.25 545587 0 607115 607392 1 12 0 13 13 13 8 yes - no 0 0 00:01:50.25 00:25:38.20 607393 0 653768 654019 1 13 0 14 14 14 8 yes - no 0 0 00:03:39.19 00:29:18.09 654020 0 754418 754615 1 14 0 15 15 15 8 yes - no 0 0 00:01:59.25 00:31:18.04 754616 0 811839 812114 1 15 0 16 16 16 8 yes - no 0 0 00:02:08.10 00:33:26.14 812115 0 874224 874438 1 16 0 17 17 17 8 yes - no 0 0 00:02:17.10 00:35:43.24 874439 0 933280 933567 1 17 0 18 18 18 8 yes - no 0 0 00:00:56.00 00:36:39.24 933568 0 956602 956878 1 18 0 19 19 19 8 yes - no 0 0 00:01:42.11 00:38:22.05 956879 0 1001865 1002028 1 19 0 20 20 20 8 yes - no 0 0 00:02:02.29 00:40:25.04 1002029 0 1056875 1057331 1 20 0 21 21 21 8 yes - no 0 0 00:03:43.01 00:44:08.05 1057332 0 1152614 1152945 1 21 0 22 22 22 8 yes - no 0 0 00:01:48.09 00:45:56.14 1152946 0 1192804 1193037 1 22 0 23 23 23 8 yes - no 0 0 00:04:04.20 00:50:01.04 1193038 0 1300344 1300584 1 23 0 24 24 24 8 yes - no 0 0 00:02:03.00 00:52:04.04 1300585 0 1341117 1341306 1 24 0 25 25 25 8 yes - no 0 0 00:00:03.11 00:52:07.15 1341307 0 1342734 1342948 1 25 0 26 26 26 8 yes - no 0 0 00:01:37.14 00:53:44.29 1342949 0 1380418 1380665 1 26 0 27 27 27 8 yes - no 0 0 00:03:20.00 00:57:04.29 1380666 0 1472009 1472418 1 27 0 28 28 28 8 yes - no 0 0 00:00:25.00 00:57:29.29 1472419 0 1483654 1483871 1 28 0 29 29 29 8 yes - no 0 0 00:02:52.15 01:00:22.14 1483872 0 1559199 1559448 1 29 0 30 30 30 8 yes - no 0 0 00:02:49.11 01:03:11.25 1559449 0 1638382 1638535 1 30 0 31 31 31 8 yes - no 0 0 00:01:59.19 01:05:11.14 1638536 0 1690914 1691323 1 31 0 32 32 32 8 yes - no 0 0 00:02:25.00 01:07:36.14 1691324 0 1753222 1753531 1 32 0 33 33 33 8 yes - no 0 0 00:05:11.10 01:12:47.24 1753532 0 1893694 1894043 1 33 0 34 34 34 8 yes - no 0 0 00:03:09.05 01:15:56.29 1894044 0 1970303 1970631 1 34 0 35 35 35 8 yes - no 0 0 00:01:45.10 01:17:42.09 1970632 0 2017889 2018182 1 35 0 36 36 36 8 yes - no 0 0 00:01:06.15 01:18:48.24 2018183 0 2042626 2042981 1 36 0 37 37 37 8 yes - no 0 0 00:03:09.20 01:21:58.14 2042982 0 2130679 2131058 1 37 0 38 38 38 8 yes - no 0 0 00:02:42.15 01:24:40.29 2131059 0 2214343 2214726 1 38 0 39 39 39 8 yes - no 0 0 00:02:04.25 01:26:45.24 2214727 0 2262969 2263249 1 39 0 40 40 40 8 yes - no 0 0 00:02:37.06 01:29:23.00 2263250 0 2320820 2321082 1 40 0 41 41 41 8 yes - no 0 0 00:04:10.25 01:33:33.25 2321083 0 2421421 2421705 1 41 0 42 42 42 8 yes - no 0 0 00:03:49.05 01:37:23.00 2421706 0 2522670 2522973 1 42 0 43 43 43 8 yes - no 0 0 00:01:56.24 01:39:19.24 2522974 0 2566138 2566320 1 43 0 44 44 44 8 yes - no 0 0 00:01:19.10 01:40:39.04 2566321 0 2595557 2595810 1 44 0 45 45 45 8 yes - no 0 0 00:02:05.25 01:42:44.29 2595811 0 2644821 2645221 1 45 0 46 46 46 8 yes - no 0 0 00:01:33.16 01:44:18.15 2645222 0 2681242 2681423 1 46 0 47 47 47 8 yes - no 0 0 00:01:37.09 01:45:55.24 2681424 0 2721726 2721934 1 47 0 48 48 48 8 yes - no 0 0 00:02:14.26 01:48:10.20 2721935 0 2781475 2781938 1 48 0 49 49 49 8 yes - no 0 0 00:04:19.19 01:52:30.09 2781939 0 2896383 2896614 1 49 0 50 50 50 8 yes - no 0 0 00:02:05.25 01:54:36.04 2896615 0 2948158 2948521 1 50 0 51 51 51 8 yes - no 0 0 00:03:31.15 01:58:07.19 2948522 0 3041026 3041408 1 51 0 52 52 52 8 yes - no 0 0 00:02:10.21 02:00:18.10 3041409 0 3096466 3096741 1 52 0 53 53 53 8 yes - no 0 0 00:04:27.10 02:04:45.20 3096742 0 3199746 3199768 1 53 0 54 54 54 8 yes - no 0 0 00:00:00.15 02:04:46.05 3199769 0 3199769 3199956 1 54 -
Hum, apparently, all cells are normal. But the duration of the first cell is only 20 seconds. Perhaps it's a black cell, without real video content, remaining from the protection.
To confirm, do this:
- Double-click the PGC in the left pane to open the PGC Editor.
- In the cells list (bottom right part of the window), click the Play button to the right of the first cell (in the first line of the list, not the Play button in the headers part of the list, used to play the whole PGC.)
If the cell is completely black or if the preview has trouble playing it, you should remove it:
- Click the Remove Cells button in the bottom of the window.
- In the little dialog, select Remove One Cell and Cell 1.
- OK the dialogs, and save the DVD.
- Optionally, use FixVTS or VobBlanker to remove the (now unreferenced) cell from the VOB. (That's not really necessary, but it's a good idea if you need to regain some disc space.) If you use VobBlanker, just process the whole DVD. You don't have to tell it what it should remove. Since the cell is unreferenced, it will be dropped anyway.
If you prefer, you can also start again from scratch, and rip the main movie of the original DVD with dvdshrink, but this time, use the "Set Start/End Frames" option to start the rip after the first cell.
If the first cell has meaningful content (for example, if it's a studio logo), you should not remove it (unless you want to remove the logo anyway, but that will not help to play the DVD). And if it's the case, that will confirm that it's an hardware problem.r0lZ - PgcEdit homepage Hosted by VideoHelp (Thanks Baldrick)
It's a studio logo, which as you say, I do not want to remove.
Is there a number of things I would need to know to learn how to identify whether or not all cells are normal myself? I trust what you say, but I'm curious about an alternate method I used to process the DVD where I skipped the demux and mux stages. So I only used DVD Shrink and PgcEdit for this one. Here's what the info looks like for it:
Code:VTST 1 , 1 TTN 1 (2:04:46) Title 1 - Chapters: 51, Programs: 51, Cells: 54 ********** pre commands: 1 Set gprm(0) =(mov) 0 ********** post commands: 1 Exit ********** cell commands: Playback time: 02:04:46.05 (at 30 fps) PG Playback mode: sequential PUOs: 0 (0x00000000) NextPGCN: 0 PrevPGCN: 0 GoUpPGCN: 0 PGC Still Time: 0 Audio stream 1 status: 0x00008000 (stream=0) Subpic stream 1 status: 0x80000000 (streams for 4:3=0, wide=0, letterbox=0, pan&scan=0) BOVs Chap. Prog. Cell Type Seam- Ang VOBU Cell Cell Playback End Entry First Last Last VOB Cell (PTT) Flags less Still Still Cmd. Time Time VOBU ILVU VOBU VOBU ID ID Joint Time # sector End Start End 0 1 1 1 2 no - no 0 0 00:00:20.25 00:00:20.25 0 0 5899 6020 1 1 0 2 2 2 8 yes - no 0 0 00:01:36.04 00:01:56.29 6021 0 38647 39091 1 2 0 3 3 3 8 yes - no 0 0 00:02:18.11 00:04:15.10 39092 0 103079 103496 1 3 0 4 4 4 8 yes - no 0 0 00:04:02.05 00:08:17.15 103497 0 211687 212066 1 4 0 5 5 5 8 yes - no 0 0 00:01:48.19 00:10:06.04 212067 0 257555 257738 1 5 0 6 6 6 8 yes - no 0 0 00:02:42.10 00:12:48.14 257739 0 329069 329420 1 6 0 7 7 7 8 yes - no 0 0 00:02:14.20 00:15:03.04 329421 0 391569 391830 1 7 0 8 8 8 8 yes - no 0 0 00:01:16.06 00:16:19.10 391831 0 426651 426979 1 8 0 9 9 9 8 yes - no 0 0 00:02:00.06 00:18:19.16 426980 0 471833 471974 1 9 0 10 10 10 8 yes - no 0 0 00:01:15.28 00:19:35.14 471975 0 502959 503126 1 10 0 11 11 11 8 yes - no 0 0 00:01:37.05 00:21:12.19 503127 0 545327 545588 1 11 0 12 12 12 8 yes - no 0 0 00:02:35.06 00:23:47.25 545589 0 607117 607394 1 12 0 13 13 13 8 yes - no 0 0 00:01:50.25 00:25:38.20 607395 0 653770 654022 1 13 0 14 14 14 8 yes - no 0 0 00:03:39.19 00:29:18.09 654023 0 754421 754618 1 14 0 15 15 15 8 yes - no 0 0 00:01:59.25 00:31:18.04 754619 0 811842 812118 1 15 0 16 16 16 8 yes - no 0 0 00:02:08.10 00:33:26.14 812119 0 874228 874441 1 16 0 17 17 17 8 yes - no 0 0 00:02:17.10 00:35:43.24 874442 0 933283 933571 1 17 0 18 18 18 8 yes - no 0 0 00:00:56.00 00:36:39.24 933572 0 956605 956881 1 18 0 19 19 19 8 yes - no 0 0 00:01:42.11 00:38:22.05 956882 0 1001869 1002032 1 19 0 20 20 20 8 yes - no 0 0 00:02:02.29 00:40:25.04 1002033 0 1056879 1057335 1 20 0 21 21 21 8 yes - no 0 0 00:03:43.01 00:44:08.05 1057336 0 1152618 1152949 1 21 0 22 22 22 8 yes - no 0 0 00:01:48.09 00:45:56.14 1152950 0 1192808 1193041 1 22 0 23 23 23 8 yes - no 0 0 00:04:04.20 00:50:01.04 1193042 0 1300349 1300588 1 23 0 24 24 24 8 yes - no 0 0 00:02:03.00 00:52:04.04 1300589 0 1341121 1341311 1 24 0 25 25 25 8 yes - no 0 0 00:00:03.11 00:52:07.15 1341312 0 1342738 1342952 1 25 0 26 10 yes - no 0 0 00:01:37.14 00:53:44.29 1342953 0 1380424 1380670 2 1 0 26 26 27 8 yes - no 0 0 00:03:20.00 00:57:04.29 1380671 0 1472015 1472423 2 2 0 27 27 28 8 yes - no 0 0 00:00:25.00 00:57:29.29 1472424 0 1483660 1483877 2 3 0 29 8 yes - no 0 0 00:02:52.15 01:00:22.14 1483878 0 1559205 1559454 2 4 0 28 28 30 8 yes - no 0 0 00:02:49.11 01:03:11.25 1559455 0 1638388 1638541 2 5 0 29 29 31 8 yes - no 0 0 00:01:59.19 01:05:11.14 1638542 0 1690920 1691329 2 6 0 30 30 32 8 yes - no 0 0 00:02:25.00 01:07:36.14 1691330 0 1753228 1753537 2 7 0 31 31 33 8 yes - no 0 0 00:05:11.10 01:12:47.24 1753538 0 1893700 1894049 2 8 0 32 32 34 8 yes - no 0 0 00:03:09.05 01:15:56.29 1894050 0 1970309 1970637 2 9 0 33 33 35 8 yes - no 0 0 00:01:45.10 01:17:42.09 1970638 0 2017896 2018189 2 10 0 34 34 36 8 yes - no 0 0 00:01:06.15 01:18:48.24 2018190 0 2042633 2042988 2 11 0 35 35 37 8 yes - no 0 0 00:03:09.20 01:21:58.14 2042989 0 2130685 2131065 2 12 0 36 36 38 8 yes - no 0 0 00:02:42.15 01:24:40.29 2131066 0 2214350 2214733 2 13 0 37 37 39 8 yes - no 0 0 00:02:04.25 01:26:45.24 2214734 0 2262976 2263256 2 14 0 38 38 40 8 yes - no 0 0 00:02:37.06 01:29:23.00 2263257 0 2320828 2321090 2 15 0 39 39 41 8 yes - no 0 0 00:04:10.25 01:33:33.25 2321091 0 2421428 2421712 2 16 0 40 40 42 8 yes - no 0 0 00:03:49.05 01:37:23.00 2421713 0 2522677 2522981 2 17 0 41 41 43 8 yes - no 0 0 00:01:56.24 01:39:19.24 2522982 0 2566146 2566328 2 18 0 42 42 44 8 yes - no 0 0 00:01:19.10 01:40:39.04 2566329 0 2595565 2595817 2 19 0 43 43 45 8 yes - no 0 0 00:02:05.25 01:42:44.29 2595818 0 2644829 2645229 2 20 0 44 44 46 8 yes - no 0 0 00:01:33.16 01:44:18.15 2645230 0 2681250 2681430 2 21 0 47 10 yes - no 0 0 00:01:37.09 01:45:55.24 2681431 0 2721735 2721943 3 1 0 45 45 48 8 yes - no 0 0 00:02:14.26 01:48:10.20 2721944 0 2781484 2781947 3 2 0 46 46 49 8 yes - no 0 0 00:04:19.19 01:52:30.09 2781948 0 2896392 2896623 3 3 0 47 47 50 8 yes - no 0 0 00:02:05.25 01:54:36.04 2896624 0 2948167 2948530 3 4 0 48 48 51 8 yes - no 0 0 00:03:31.15 01:58:07.19 2948531 0 3041036 3041417 3 5 0 49 49 52 8 yes - no 0 0 00:02:10.21 02:00:18.10 3041418 0 3096475 3096750 3 6 0 50 50 53 8 yes - no 0 0 00:04:27.10 02:04:45.20 3096751 0 3199755 3199779 3 7 0 51 51 54 2 no - no 0 0 00:00:00.15 02:04:46.05 3199780 0 3199780 3199966 4 1 -
In protected DVDs with fake cells, there are usually several very short cells at the beginning of the PGC. In the original disc, some of them are skipped with cell commands, and that skipped cells are not readable, because they contain intentionally some bad blocks with errors. That bad blocks are the protection. When a DVD copier or ripper tries to extract them, it hangs and retries during hours or even days, unless it is smart enough to ignore then and remove them from the copy.
When the movie is ripped with dvdshrink, it removes the cell commands anyway, and it should remove also the bad cells, but I'm not sure it does that. So if, for any reason, it doesn't detect and remove correctly the protected cells, it may leave some blocks with unreadable garbage. And since they are not skipped any more due to the missing cell commands, the player must play them. Playing a protected cell may result in big problems for the DVD player, before it gives up and continue with the next cell, or simply crash. It's also why trying to preview a bad cell with PgcEdit should fail or display only black frames.
Since in your case, there is only one (relatively) short cell at the beginning of the PGC, it doesn't look like a protected PGC. You have confirmed that the first cell is not protected.
So, dvdshrink did its job correctly, and the DVD doesn't seem to be protected. Only the hardware remains to explain your problem. Try to burn only Verbatim discs, with a good burner and ImgBurn. I can't help more, sorry.r0lZ - PgcEdit homepage Hosted by VideoHelp (Thanks Baldrick)
Confused with TS Muxer & it's audio delay for DVD VOB's
By Gurd99 in forum Newbie / General discussionsReplies: 4Last Post: 1st Oct 2015, 05:50 -
Panasonic DMR ES15 DVD drive problem stuck on loading cycle
By mammo1789 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 8th Jan 2015, 17:40 -
Do I need to set audio delay when editing DVD?
By Mession77 in forum DVD RippingReplies: 2Last Post: 22nd May 2012, 04:47 -
Audio to video delay value on a DVD
By nic2k4 in forum EditingReplies: 20Last Post: 7th Dec 2011, 04:06 -
audio delay after encoding, but not after ripping the DVD
By codemaster in forum DVD RippingReplies: 18Last Post: 21st Mar 2011, 17:03
