  1. How do I convert an .ASF file to VCD? tried using tmpgnc then burned with nero and the sound is broken up. How do I do this the correct way? Any suggestions are much appreciated.
    Thanks in advance
  2. Get VirtualDub v1.3a and/or TMPGEnc 12a and they will be able to handle the ASF file format better then the new versions.
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
  3. Thanks, but where would I find Vdub v1.3a?
  4. Try using google to search for it, i'm quite positive you will find it easily.
    Best Regards,
    Sefy Levy,
  5. If you use Nero, just go to there page and download there WMA Plugin
    it will convert the asf or wma as it writes the VCD. Its much faster then then Tempg. Some look good some don t depends on the video in. And its free !
    Good luck
