    Feb 2016
    Toronto, Canada
    Hello,
    I don't which forum I should post this in, but here's my inquiry:
    I would like to automatically convert a folder of MKVs from AC3 audio to AAC using a script of some sort.
    Does anyone know how I could accomplish this?
    Thanks.
  2. you can try to use ffmpeg and mapping, it depends how many streams those mkv's have and order, it perhaps going to be always the same, , for example 3 (video, audio, subs) adapted from its mapping manual:
    ffmpeg -i input.mkv  -map 0:0 -map 0:1 -map 0:2  -c:v copy  -c:a libfaac -b:a 256k  -c:s copy  output.mkv
    But, what is the reason you'd do that?
  3. Member DB83's Avatar
    Jul 2007
    Lots of info on here how to get what you want.
    Check out the 'RULES'. Especially the 'Warez' section.
    Feb 2016
    Toronto, Canada
    Edited to conform to rules.
