    Feb 2016
    Lithuania
    Hello, so I want to extract Teletext subtitles from .ts file. I am using ProjectX, but I need 803 Teletext page and I can't select that in ProjectX becouse that page doesn't exist in ProjectX. What should I do? Is there any other programs like ProjectX?
    File info:
    Video
    Menu ID                     : 5111 (0x13F7)
    Format                      : MPEG Video
    Format version              : Version 2
    Format profile              : Main@Main
    Format settings, BVOP       : Yes
    Format settings, Matrix     : Custom
    Format settings, GOP        : Variable
    Format settings, picture st : Frame
    Codec ID                    : 2
    Duration                    : 19mn 43s
    Bit rate                    : 3 143 Kbps
    Maximum bit rate            : 3 000 Kbps
    Width                       : 720 pixels
    Height                      : 576 pixels
    Display aspect ratio        : 16:9
    Frame rate                  : 25.000 fps
    Standard                    : PAL
    Color space                 : YUV
    Chroma subsampling          : 4:2:0
    Bit depth                   : 8 bits
    Scan type                   : Interlaced
    Scan order                  : Top Field First
    Compression mode            : Lossy
    Bits/(Pixel*Frame)          : 0.303
    Time code of first frame    : 00:00:00:00
    Time code source            : Group of pictures header
    GOP, Open/Closed            : Open
    Stream size                 : 444 MiB (85%)
    Audio #1
    Format                      : MPEG Audio
    Format version              : Version 1
    Format profile              : Layer 2
    Codec ID                    : 3
    Duration                    : 19mn 43s
    Bit rate mode               : Constant
    Bit rate                    : 192 Kbps
    Channel(s)                  : 2 channels
    Sampling rate               : 48.0 KHz
    Delay relative to video     : 23ms
    Stream size                 : 27.1 MiB (5%)
    Language                    : Russian
    Audio #2
    Format                      : MPEG Audio
    Mode                        : Joint stereo
    Mode extension              : Intensity Stereo + MS Stereo
    Codec ID                    : 3
    Duration                    : 19mn 43s
    Bit rate                    : 192 Kbps
    Language                    : English
    Text #1
    Format                      : DVB Subtitle
    Codec ID                    : 6
    Duration                    : 19mn 39s
    Delay relative to video     : 4s 87ms
    Language                    : Estonian
    Text #2
    Codec ID                    : 6
    Duration                    : 19mn 40s
    Delay relative to video     : 2s 947ms
    Language                    : Latvian
    Text #3
    Codec ID                    : 6
    Duration                    : 19mn 21s
    Delay relative to video     : 5s 467ms
    Language                    : Lithuanian
    Text #4
    ID                          : 2789 (0xAE5)-599
    Format                      : Teletext Subtitle
    Language                    : Latvian
    Text #5
    ID                          : 2789 (0xAE5)-801
    Language                    : Estonian
    Text #6
    ID                          : 2789 (0xAE5)-803
    Menu
    Duration                    : 19mn 43s
    List                        : 1201 (0x4B1) (MPEG Video) / 2784 (0xAE0) (MPEG Audio, Russian) / 2785 (0xAE1) (MPEG Audio, English) / 2786 (0xAE2) (DVB Subtitle, Estonian) / 2787 (0xAE3) (DVB Subtitle, Latvian) / 2788 (0xAE4) (DVB Subtitle, Lithuanian) / 2789 (0xAE5) ()
    Language                    :  / Russian / English / Estonian / Latvian / Lithuanian
    Jul 2008
    Old Dominion
    Have you tried CCextractorGUI?
    Feb 2016
    Lithuania
    Yeah I have tried it didin't really work. I found the program that worked just now, TS-Doctor.
  4. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    OMG! All you have to do in ProjectX is TYPE the page number in the box - the drop down menu has a collection of well known pages. In Australia the page number is 801 - it doesn't exist in the drop down list either. So place the cursor in the top left hand box where hit the backspace key a few time to clear what might be there and then type the numbers in. Simple!
