Results 1 to 12 of 12
    Aug 2010
    israel
    Greetings
    Is there anything I can do to get the audio in subtitle workshop (6.0b) with few mp4 files?
    OS: still win7
    thank you
    Aug 2010
    israel
    forgot something:
    only with AC-3 audio
    when audio is AAC or MP3 I have no problem with the audio
    thanks
    Or ac3filter.
    Or try Subtitle Edit.
    Aug 2010
    israel
    subtitle edit did not respond either
    ffdshow and ac3filter will be installed
    thank you
    Aug 2010
    israel
    installed both ffdshow and ac3filter and it didn't help
    maybe I shouldn't have installed them both or do something with these programs or subtitle workshop configuration that I don't know
    thanks again
  6. subtitle edit did not respond either
    Did you choosde VLC as player?
    http://www.nikse.dk/SubtitleEdit/Help#codecs
    Aug 2010
    israel
    yes I tried external previews: kmplayer, mpc, vlc and it didn't help either.
    but I hear the sound with no problems with video players, the problem is when I tried to add subtitle with subtitle workshop
    only with subtitle workshop I can't here sound from mp4 files with ac-3 audio
  8. you're right,my fault
    I tested...
    Subtitle Workshop (6.0b) really no audio on MP4 (when the audio AC3)
    Why ? I have no idea...I tried everything (Codec Tweak Tool,ffdshow -adjust the audio decoder,etc...and etc...) not at all...
    Also (for proper operation Subtitle Workshop) only need to install Haali Media Splitter and ffdshow (nothing more is required).
    Video renderer you can put (VMR9).
    Further...
    MKV and AVI (even VOB) "nice open" (when the audio AC3)...why will not "withdraw" ffdshow (audio decoder) on MP4 ? I really do not know...
    Only solution : remux MP4 to MKV with MKVToolnix,then fix subtitles with Subtitle Workshop etc.
    or use Subtitle Edit (as colleagues have recommended),greeting...
    Aug 2010
    israel
    thank you
    converting mp4 to mkv (like any converting) will damage quality of the HD mp4 files I was talking about.
    I sent a mail to subtitle workshop support and didn't get an answer.
    Maybe a better way will be to convert audio to AAC, if I only knew how.
    Is format factory good enough for changing the audio?
  10. I'm a MEGA Super Moderator Baldrick's Avatar
    No. You wont lose quality when using Mkvtoolnixgui to change to mkv. It will ONLY remux/change container to mkv and not reconvert any video/audio.
    Aug 2010
    israel
    thanks. I trust you, and I already upgraded MKVToolnix.
    But I thing converting just the audio from AC3 to AAC with format factory is also a good idea (though converting the audio must be done with careful attention to parameters)
