Hello! I'm a total newbie in encoding, and I have a question for you guys.
I have 2 videos in mp4 format. First is a short video about 1min. The second is a bigger movie. I want to join these 2 files.
The first video info are: Generale
Complete name : E:\preroll\Preroll.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (isom/mp42)
File size : 6,41
Duration : 1mn 40s
Overall bit rate : 537
Encoded date : UTC 2016-01-20 10:21:26
Tagged date : UTC 2016-01-20 10:21:26
Video
Format : AVC
Format profile : Main@L3.1
Format settings, CABAC : Da
Format settings, ReFrames : 3 frame
Format settings, GOP : M=1, N=75
Codec ID : avc1
Duration : 1mn 40s
Bit rate : 281
Width : 1 280pixeli
Height : 720pixeli
Display aspect ratio : 16:9
Frame rate : 15,000pfs
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8biti
Bits/(Pixel*Frame) : 0.020
Stream size : 3,36 (52%)
Color range : Limited
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 1mn 40s
Bit rate : 254
Maximum bit rate : 408
Channel(s) : 2canale
Sampling rate : 44,1
Frame rate : 43,066pfs (1024 spf)
Stream size : 3,03 (47%)
For the second video: Generale
Complete name : E:\30915_04_720p.mp4
Format : MPEG-4
Codec ID : isom (isom/iso2/avc1/mp41)
File size : 878
Duration : 24mn 34s
Overall bit rate : 4 993
Writing application : Lavf56.40.101
Video
Format : AVC
Format profile : High@L3.1
Format settings, ReFrames : 4 frame
Codec ID : avc1
Duration : 24mn 34s
Bit rate : 4 800
Width : 1 280pixeli
Height : 720pixeli
Frame rate : 29,970 (29970/1000)pfs
Color space : YUV
Bit depth : 8biti
Bits/(Pixel*Frame) : 0.174
Stream size : 842 (96%)
Writing library : x264 core 148
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=22 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=4800 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 24mn 34s
Duration_LastFrame : -6
Bit rate : 192
Stream size : 33,7 (4%)
Default : Da
Alternate group : 1
I know that I need to reencode the videos so I can join them, but I don't want to reencode the second video that is bigger and takes a lot of time. I want to reencode the first video to be exactly in the same format as the second so I can simply join the files fast. Can someone help me and give me more info about what software to use and what settings to use so I can convert the first video in the same format as the second?
Thank you!
You could just try vidcoder and under settings change everything so close as the second video as possible. AVC=H.264/x264. But I guess it will be hard to get exact same settings so you can join. And then 15fps to 29.97fps....
Then join with myMp4boxgui.
cutting mts files and joining without lipsync problem
By oduodui in forum EditingReplies: 1Last Post: 27th Aug 2014, 20:43 -
Problem with joining 2 mkv files
By lascetic in forum EditingReplies: 7Last Post: 30th Jun 2014, 06:13 -
Joining mpgs
By Jon.G in forum Video ConversionReplies: 14Last Post: 13th Dec 2013, 03:12 -
Joining Mpeg files problem
By efiste2 in forum EditingReplies: 19Last Post: 21st Apr 2013, 14:42 -
audio sync problem joining two avi files
By kthan in forum EditingReplies: 11Last Post: 2nd Apr 2011, 12:52
