Hello,
i am completely new to this.
I have got 200+ season of series of which i want to merge the SRT with the MKV
Can anybody help me on this?
I want to merge all MKV files (also setting the language to English) with the SRT files (setting language to Dutch)
Is there a simple way of merging these files season by season while making the proper language settings?
Doing it episode by episode will take me ages since there are over 4500 episodes.
I started out with creating 2 folders on my desktop (one called "to merge", the other "merged" thinking this maybe would prove easier
Thanks guys!
Please only post GUIDES in the guides section. I'm moving you to our general section.
Hi,
I had the same problem as yourself and put together the below PowerShell Script to achieve the batch muxing of subtitles.
#Batch Merge Subtitles with MKVMerge - Iain McCain
#Set MKVMerge.exe Path
$MKVMerge = 'C:\Program Files\MKVToolNix\mkvmerge.exe'
#Set Target
$Directory = "Z:\Films\"
#Set Subtitle Extension
$SubExtension = 'eng.srt'
#Process
$Subs = Get-ChildItem $Directory -Filter "*.$SubExtension" -Recurse | % { $_.FullName } | Sort-Object
$Count = $Subs.count
Write-Host "$Count MKV's to be processed."
Foreach ($Sub in $Subs)
#Get File Name
$FormatName = $Sub.ToString()
$Name = $FormatName.TrimEnd(".$SubExtension")
$MKV = $Name + '.mkv'
#Set Output File Name
$Output = $Name + '___MERGED' + '.mkv'
#Execute
& $MKVMerge -o "$Output" --default-track "0" --language "0:eng" "$Sub" "$MKV"
#Clean Up
Remove-Item $MKV
Remove-Item $Sub
Rename-Item $Output -NewName $MKV
Batch convert a lot of mp4, different framerate/bitrate, and merging.. help
By Jerryskate in forum Video ConversionReplies: 0Last Post: 14th Jul 2014, 04:50 -
Batch tool to conbert srt to ssa/ass
By dudul in forum SubtitleReplies: 3Last Post: 15th Nov 2012, 17:02 -
Batch extract srt from multiple Mkv's?
By gosa in forum MacReplies: 59Last Post: 21st Apr 2012, 17:30 -
Merging NOT joining SRT files
By pmshah in forum SubtitleReplies: 3Last Post: 20th Sep 2011, 00:02 -
Batch Converting ASS to SRT
By sickonsin in forum SubtitleReplies: 5Last Post: 30th Apr 2011, 17:12
