Has anyone ever figured out what's up with those DivX AVI's that show the audio format as: Unknown (tag 2000) - like when you check the file information from VirtualDub?
I've seen reference too it, but no posts at all about what codec this is, and how to extract this audio from an AVI. VirtualDub can't do it.
Has anyone ever tried to change the tag with one of those tag editors?
When it's talking about tag, I assume this is the fourcc? Just out of curiousity, what is the fourcc for Dolby (AC3) audio? I'm thinking it's really AC3, but the tag is wrong.. maybe it was created with a crappy encoder... just guessing.
Must be AC3 or OGG... I followed the instructions below, and can now open audio in TMPGEnc.. but not sure why virtualdub can't open? What's DirectShow Multimedia File Reader? What's the fourcc code for ac3 and ogg audio?
Convert DivX with AC3 or OGG Audio
Install first an AC3 audio decoder or OGG Audio Codec if you haven't done that, Nimo Codec Pack includes both or/and you could install WinDVD that also includes a AC3 Decoder. You should be able to play the DivX with AC3 or OGG with Windows Media Player.
Launch TMPGenc v2.52 or higher and before opening the video you need to change the priority of the directshow reader, under under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 1 or 2. Now open the video and the audio should be automatically be opened. If this do not work try this method. -
see how i solved it .look under no one has sloved this yet in newbee conversion.
mabos22 -
Huh... what are you trying to say... you solved it? how? look under what?
You mean this post: http://forum.vcdhelp.com/viewtopic.php?t=87701&highlight=solved? I posted above that I solved this already using another tool, so I thought you were answering the additional questions I asked... about Directshow and the fourcc codes.
Ripping CD (Enhanced Video) Unknown Format
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 30th Jan 2011, 20:20 -
Adventures in importing... unknown format in .mov wrapper
By vidhelp22 in forum Video ConversionReplies: 2Last Post: 19th Oct 2010, 23:30 -
Capturing unknown format video 8
By Bigby in forum Capturing and VCRReplies: 17Last Post: 28th Sep 2009, 09:10 -
Unknown Disc on Tevion Model no TCHT 2000
By Brimac in forum Newbie / General discussionsReplies: 5Last Post: 1st Jan 2008, 11:39 -
Mpeg-1 Audio Layer 2 - Audio Tag 50 - VirtualDub, TMPEGEnc Can't Read
By Rebooter in forum AudioReplies: 2Last Post: 26th Oct 2007, 21:51
