    Jul 2001
    Are there any minimum system requirements for ripping DVDs to SVCD? Is there any risk for dropped frames, lost sync or will just take a looong time? (I have a Celeron 333, DMA/33)
  2. i never had a problem and i have a celeron 333 with 96meg ram and 6x toshiba dvd-rom using w2k.
    you just copy the vobs to the harddrive shouldn't be any dropped frames at all.
    make sure you have plenty of drive space...
    Keith
    May 2001
    PokeMP3
    you'll be amazed, but i have managed to make a svcd from DVD with a 486!!.
    the only problem was the burning part; i had to do that with my celeron 466.
    btw, you better keep useing the celeron or a better system for it. by the time you fully ripped a dvd with a 486 you'll be 87 (asumeing you are 21 now).
    NdZ
    Jun 2001
    st. louis, mo, usa
    you rule.
    i how long was the movie, and how long did it take you to make it? what software did you use?
    that is awesome that you did that.
    i have a p2-300 and i thought mine would take a long time!
    more power to you man.
    later
    THIS IS HARDCORE
    May 2001
    PokeMP3
    i just ripped the Dolby Digital intro for testing perpose; just wondered how long it would take. all in total i think it took me one month alltogether.
    the p2 300 is simular to my system. useing LSX Mpeg encoder, it takes me roughly 20/25 times the length of the DVD cuz i put everything on highest quality possible.
    i think you'll need the same amount of time
    g'luck
    NdZ
