Hello,
I have read through some older threads regarding the splitting, trimming, and joining of mts camcorder files and I have to say I am thoroughly confused.
Q1. Is it less grief overall to convert the mts files to another type before attempting any editing ?
Q2. If so which type will avoid or minimize re-encoding / quality loss ?
Q3. If not, then can someone recommend a freeware that can handle mts well ?
	1. You will lose quality by reconverting. If you are not converting to a lossless format but it will be HUGE so you must shrink/reconvert it again.
 3. You could split and join lossless with tsmuxer (write time codes, no video preview), avidemux (it will crash ),  TSSNiper (may not support all mts files), Free Video Editor (adware). ),  TSSNiper (may not support all mts files), Free Video Editor (adware).
 But if you are going trim lots of mts lossless then get/buy good editor like videoredo h264 suite, tmpgenc smart renderer, solveigmm video splitter. Try trials first!
	Could you give an example of a lossless format that I could experiment with ?
 I will try these to see if any of them can do what I need.
 I don't mind trying new software. The hassle is cleaning it out of your hard drive. It usually means doing a disk image before install and then a restore afterwards when you realize that it is not going to be a happy marriage.
  cutting mts files and joining without lipsync problemBy oduodui in forum EditingReplies: 1Last Post: 27th Aug 2014, 21:43
  Splitting/Joining AVCHD video files (m2ts)By glenpinn in forum EditingReplies: 17Last Post: 19th Sep 2012, 12:13
  Joining .MTS files without it glitching outBy Danboyland in forum Newbie / General discussionsReplies: 3Last Post: 29th Apr 2012, 11:35
  Joining mts files to one video with chapters (Blu-ray)By Gibbus in forum Authoring (Blu-ray)Replies: 1Last Post: 2nd Oct 2011, 04:25
  Basic newbie question about trimming/splittingBy lboiv001 in forum Newbie / General discussionsReplies: 4Last Post: 24th May 2011, 15:56
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
