Am undertaking converting VHS to digital format and I am seeking recommendations for a good video + audio capture card for a PC. I have two machines available:
One PC I have will accept PCI and PCI-e - has xp, and 4 MB (i forget the AMD processor-about 7 yo)
The other PC I have will accept PCI-e, x1, x16, x32. - has win7, 32GB, i5- 3.3 Ghz
I prefer to use the i5 machine. I'd like to get a PCI-e bus card so, if necessary, I can use with either machine.
I am OK with older/used cards as well a new ones. I know codecs play a large part in the quality as well. Basically am looking for recommendations from ppl who have had good success with a card.
Advice much appreciated...
J
I could answer your question, but I think telling you how to use this forums resources to find the answer on your own might be more beneficial in the long run. Try using VideoHelp's forum search feature (in the top right corner of this webpage) to see if it turns up anything helpful. The results can be ordered by date. A few other people have made a similar request in recent months.
Wouldn't it make sense to have a sticky in the capture section with the -current- recommended capture chain for analog tapes, it is a recurrent and legitimate question.
That thought occurred to me as I was casting around in this site for a few hours (before I posted my question). The closest thing I found is:
http://www.digitalfaq.com/forum/video-capture/3200-best-ati-wonder.html
and it is not on this site.
Recommendation for capture card with more than 1 live output
By nullptr in forum Capturing and VCRReplies: 5Last Post: 14th Oct 2014, 14:14 -
Need a recommendation for most inexpensive hdmi capture card
By gil900 in forum Capturing and VCRReplies: 10Last Post: 23rd Mar 2014, 02:51 -
Good capture card recommendation...
By BrainAche in forum Capturing and VCRReplies: 7Last Post: 1st Aug 2013, 15:39 -
Recommendation for S-VHS Component Capture Device or Card
By timothyd_1975 in forum Capturing and VCRReplies: 56Last Post: 11th May 2013, 14:04 -
Need a recommendation on a new capture card/device
By MJDore in forum Capturing and VCRReplies: 1Last Post: 14th Oct 2011, 16:56
