I see that the WinTV takes a coax connection - is it possible to capture HD from a cable box with this device?
Only unencrypted QAM. Most cable companies are switching to encrypting all channels to force you to pay for their cable box. If you have a TV with a clear QAM tuner try it out and see what channels you get. At best you'll probably only get local broadcast channels and a bit of other junk.
My area actually requires boxes for any form of cable - I was wondering since I already have the box what would happen if I connected the cable -> cable box -> dualHD. Would I be able to capture TV from the box as if it were OTA?
Sorry premiumcapture but it dose work that way
usually_quiet is rigth the coax output on a cable box usually exists for preset channel like 3/4 for old analog tuners and the WinTV dualHD has no analog support what so ever.
New Hauppauge WinTV-dualHD TV Tuner USB and Soon a Quad Tuner PCIe
By SHS in forum DVB / IPTVReplies: 1Last Post: 21st Sep 2015, 22:30 -
Capturing cable TV: are sources equivalent (cable box vs M-card tuner)?
By Nickster in forum Capturing and VCRReplies: 5Last Post: 12th Oct 2014, 17:45 -
hauppauge 1212 and wintv extend
By tkolt in forum Media Center PC / MediaCentersReplies: 0Last Post: 18th Nov 2011, 19:56 -
Hauppauge WinTV-PVR 250
By thatsgame1 in forum Newbie / General discussionsReplies: 5Last Post: 22nd Jun 2011, 07:54 -
[Sloved] Hauppauge WinTV PVR-150 capturing using off air cable plug
By Wizard23 in forum Capturing and VCRReplies: 4Last Post: 11th Feb 2011, 22:07
