Hi,
I have some large faulty mpeg files recorded from my TV tuner card. The file when played only plays a video of around 20 seconds. Actual recording is around 1 hour.
I have tried three software, Womble MPEG Video Wizard, Grau GbRs Video Repair Tool and MPEG Corrector. The former two could only repair 1.2 MB from the 850 MB file. Thus all failed.
Please suggest a powerful professional Mpeg repair tool. Will Sony Vegas Studio be able to do something?
Thanks for help or diagnosis of the issue.
Amer
	You can try Videoredo and see if it can open the mpg video. Try the quickstream fix in it. Try trial first.
 The old ProjectX and PVAStrumento may work for some mpeg/ts tv-tuner/dvb streams also.
	Sony Vegas won't do anything (I own Vegas Pro).
 You can try using ffmpeg to simply trim a few frames from the beginning and end of the files. Sometimes these problems are caused by faulty MPEG headers.
 Take a good look at the capture software you are using with your tuner card and see if it has some sort of editing or fixing utilities.
 Contact the capture card manufacturer and ask for their help.
	Thanks for the nice suggestions.
 I will try to use the suggested software.
 Regards.
  Repair faulty single-sided audio on VOBBy Vlad888 in forum EditingReplies: 21Last Post: 6th Jul 2014, 10:16
  Are there any powerful, error free paid software to edit Mp4 & avi files?By seymoria in forum EditingReplies: 1Last Post: 8th Feb 2014, 14:34
  What software would you suggest? (replacing sound track)By JDługosz in forum EditingReplies: 4Last Post: 4th May 2013, 22:28
  repair problem Video (do not know how to describe)with faulty captureBy gil900 in forum RestorationReplies: 30Last Post: 20th Oct 2012, 16:41
  Possibility to repair HDV due to faulty cassetteBy avz10 in forum RestorationReplies: 9Last Post: 5th May 2011, 16:35
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
