I have a 1 minute long video of CSGO in 240 FPS. When I try to play the video in Vegas it's extremely choppy. If I try to render the video in 60 FPS, Vegas freezes before the rendering has finished.
I have rendered a lot of 1080p60 videos without any issues before, but this 240 FPS video seems to just ruin everything. I have tried to render with CPU only and CUDA. Same issue all the time.
Win 7
i7 4770k @ 4.2 GHz
GTX 970
8 GB RAM
What format is the video recording? Use mediainfo (view=>text) if you don't know
You won't be able to playback 240FPS at 240FPS smoothly. Also, most displays run at 60Hz anyways, so you would only see 1/4 of the frames
Probably you can't capture 240FPS at 240FPS either, not at that resolution. You probably have frame drops - that could explain the choppiness as well. If you examine it frame by frame and see gaps in motion - that is what happened. Can you provide more info on the capture setup ?
WHen you rendered 1080p60, was it sampling every 4th frame for 60 at normal speed, or slow motion (every frame, but assumed at a lower frame rate)? -
It's an AVI file. I'm capturing in 240 FPS in order to make smooth slow motion effects on some clips, but in this case I just want the whole clip to be rendered in a normal phase in 60 FPS. If I examinate the clip frame by frame there are no choppiness at all and all frames are in perfect order without any gaps whatsoever.
There is no slow motion at all, the clip is rendered in 60 FPS normal speed throughout the whole clip.
I fixed the rendering issue by disabling GPU acceleration. The rendered video is smooth but whenever I try to play the 240 FPS clip in Vegas its still extremely laggy.
Effect FX Editing in Sony Vegas
By imrealdumb in forum EditingReplies: 14Last Post: 14th Sep 2013, 20:36 -
240 fps rendering with Sony vegas pro 12 and other good Q's
By Muffdiever in forum Newbie / General discussionsReplies: 16Last Post: 2nd Jan 2013, 11:34 -
Sony Vegas 24 fps problem
By Reiden in forum EditingReplies: 6Last Post: 29th Jan 2012, 21:17 -
Best Video Editing Program ? Powerdirector or Sony vegas ?
By dudeme13 in forum Newbie / General discussionsReplies: 2Last Post: 31st Jul 2011, 10:42 -
Sony Vegas Editing help
By blecap in forum EditingReplies: 2Last Post: 30th Mar 2011, 03:08
