Hi
I am looking for a software to delete scenes from movies i.e. .mkv files. Can any once please suggest me any free or cheap software?
Depends a bit on your requirements. If it's without re-encoding free software will cut on I-frames. The distance between I-frames dependens on the video codec. Often h.264 is used in .mkv in which case the distance may be up to 10s. Video To Video, MKVToolnix, Avidemux (can be tricky)
If you want frame accurracy smart cutters can be used where only the parts of the cut to the nearst I-fram is re-encoded while the rest is copied. SolveigMM Video Splitter, VideoRedo
And any video converter can give you frame accurracy if everything is re-encoded. -
Use MkvCutter for split/cut video parts with accuracy (without encode). Then, use MKVToolnix for append them (without encode)
I want to edit a movie that contain some vulgar scenes
By prasoon kumar in forum EditingReplies: 10Last Post: 16th Jan 2015, 08:48 -
How to delete scenes from clips in Organize in Pinnacle 17.5
By avz10 in forum EditingReplies: 3Last Post: 27th Jun 2014, 18:17 -
Cutting several scenes?
By LolaFox in forum EditingReplies: 3Last Post: 13th Feb 2014, 13:37 -
Trying to delete sections of a movie with VirtualDub
By VanZan in forum EditingReplies: 1Last Post: 19th Nov 2011, 14:04 -
Need to put a bunch of movie scenes together
By neworldman in forum EditingReplies: 2Last Post: 1st Oct 2011, 21:55
