I know how to create a DVD in DVD Architect Pro 6.0 with no menus when using a single video. However, I want to import two or three videos into DVD Architect Pro to burn on a DVD with no menu so the DVD just plays from start to finish. I don't want to have to render the two (or three) videos together to create a single video so I can do this. Can this be done in DVD Architect Pro? Thanks for any help you can give me.
Set your end action for each video.
https://www.custcenter.com/app/answers/detail/a_id/4705/~/creating-a-dvd-with-multiple...-dvd-architect. -
I saw that earlier, but didn't think it was what I needed. So linking them will make it seem as if it's one file? I'll study and do it. Thanks.
It most likely cannot stich videos together directly on its timeline (without linking them).
If videos are encoded with same settings you might try some free tools to join those mpg's. Mpeg2cut2 for example. Then load it into DVD Architect.
Sony DVD Architect 5.0 Pro problems with Next button on Remote for DVD.
By romit99 in forum Authoring (DVD)Replies: 12Last Post: 6th Aug 2013, 20:54 -
Possible to burn Blu-ray to DVD with Vegas Pro 8 & DVD Architect Studio?
By brassplyer in forum Authoring (Blu-ray)Replies: 1Last Post: 17th Jan 2013, 11:44 -
DVD Architect Pro 5.2 - Dual Language Menu
By Neutral42 in forum Authoring (DVD)Replies: 6Last Post: 25th Sep 2012, 14:06 -
Audio POPS! with DVD Architect Pro 5.0
By Dissonance in forum Authoring (DVD)Replies: 2Last Post: 21st May 2012, 16:45 -
Blu-ray PopUp Menu with DVD Architect Pro 5.2?
By dabezt in forum Authoring (Blu-ray)Replies: 0Last Post: 27th Apr 2011, 03:02
