I used virtualdub to split an AVI file into 2. ( using the guide on this site ).
That seamed to work fine and I had 2 approx 40 min files which played on windows media player.
I then attempted, using NERO, to converted the files to VCD format.
The first file encodes but then I get an error 13 - DISK FULL.
The second file encodes and burns and I can play it on my DVD player.
I tried with another AVI file and exactly the same happens, The first part won,t burn and the second works fine.
HELP!!!!!!!!!
found it myself. Download nero 5580, cancel wizard, Select VCD, de-select cdi, and continue as described in the guides.
8)
thanks all
Problems re-using VirtualDub
By djdust in forum Newbie / General discussionsReplies: 17Last Post: 27th Apr 2011, 09:57 -
.mkv problems in Virtualdub
By alc112 in forum Video ConversionReplies: 14Last Post: 11th Feb 2010, 00:47 -
virtualdub dv type 2 problems
By sander815 in forum Video ConversionReplies: 26Last Post: 21st Nov 2009, 20:58 -
Problems with Virtualdub
By demonwarrior in forum Newbie / General discussionsReplies: 4Last Post: 8th Jun 2007, 10:23 -
A couple of VirtualDub problems.
By Rein Engel in forum Capturing and VCRReplies: 5Last Post: 1st Jun 2007, 04:07
