Hey guys, I want to know, is there a way of reauthoring a DVD, which has more than 1 angle. Now, I have such DVD which is in french. I only want to replace the audio track with an english one. If you're wondering, the second angle is basically some small windows and pics, which appear during the movie, along with a commentary from the creators (if you choose it from the special features). Is there a way to do such task?![]()
I can't figure out what you're asking. If you're asking if you can replace the audio track at the same time keeping the angles, then you'd best not attempt it.
If you're willing to strip out all but one angle then, yes, it can be done. You can even do it and keep the menus, although it'll be easier if you either don't keep menus at all, or create your own menus.
Perhaps the easiest way, after decrypting the DVD to the hard drive, is to use PGCDemux to first extract the audio, video, subs, and chapters for the angle you want. Then you reauthor using Muxman, adding in the video, new audio, subs, and chapters. No menu that way but it should be easy enough. -
Sorry, if I wasn't clear enough
Here's how it is: it's a "Walking with Dinosaurs" DVD (1999 Series). It has a special feature - if you choose it, the episodes play along with some extra commentary, accompanied by pictures. This is obviously the so called second angle. The only problem is, that the entire DVD is in french. I only want to replace the french language track with an english one (if possible, add subtitles). Everything else (DVD structure, and especially the two angles) must remain the same.
Why does demuxing and remuxing 1080i video give artifacts?
By MrBiggles in forum Video ConversionReplies: 51Last Post: 15th Jun 2015, 17:21 -
Editing an mkv? (muxing or remuxing)
By justinrye in forum Newbie / General discussionsReplies: 4Last Post: 4th Oct 2014, 20:06 -
banding & demuxing/remuxing
By zanaitoryoushi in forum Video ConversionReplies: 2Last Post: 5th Sep 2012, 03:08 -
m2v stream editing. How prime to remuxing?
By transcendent in forum Newbie / General discussionsReplies: 10Last Post: 29th Jun 2012, 20:55 -
[solved] editing MKV without remuxing
By lovelove in forum Newbie / General discussionsReplies: 4Last Post: 12th Aug 2011, 10:09
