I have a track with music and sound effects included, and I also have a WAV file with my commentary. In VirtualDub, if I go to "Audio from another file," and then select my track, then the resulting video only has my commentary and the original stream is gone. And then when I go back to select Stream 1, the audio comes back and it doesn't play my commentary.
It seems like it's only letting me have one audio stream, but I know AVI files are supposed to support two streams. I would think a program with DUB in the name would be ideal for this, but the process is extremely counter-intuitive. Is there a way to do this, other than trying to extract the audio stream, mix it with my commentary in another program, and then reinsert it? Because I really don't want to do that if I don't have to, and it seems very likely to reduce sound quality.
I think the "single audio track" thing is some sort of early Windows limitation, and VirtualDub still abides by it. VirtualDubMod and AVIMuxGUI don't.
Jagabo can I manually add timecode to a virtualdub .avi mjpg file?
By marcorocchini in forum Newbie / General discussionsReplies: 13Last Post: 5th May 2014, 07:41 -
How to add hard subtitles from srt file to avi movie.
By Firewire60 in forum SubtitleReplies: 3Last Post: 23rd Dec 2013, 17:02 -
does samsung tv support second audio stream in avi file?
By matmat in forum Video ConversionReplies: 2Last Post: 8th Nov 2012, 07:21 -
add lyrics to avi file
By frednufc in forum Newbie / General discussionsReplies: 2Last Post: 4th Aug 2012, 01:33 -
VirtualDub File [path] does not have a video stream error
By fershad in forum Video ConversionReplies: 4Last Post: 25th Jan 2012, 06:11
