Results 1 to 14 of 14
  1. This is the error show when i tried to open a bluray anime(0000.m2ts) episode in avspmod. What should i do?
  2. Do you have Microsoft C++ 2013 Redistributable Package installed?
    http://www.microsoft.com/en-us/download/details.aspx?id=40784
    See the prerequisites
    http://avisynth.nl/index.php/LSMASHSource
  3. Also: you need to use lwlibavvideosource() instead of lsmashvideosource() for anything not mp4/mov.
  4. Poisondeathray - Microsoft C++ 2013 Redistributable is already installed.
    Sneaker - I changed the script with lwlibavvideosource() but i still get same error. Is it because im using 64bit lsmashsource?
  5. If you use 32 bit AviSynth you need to use 32 bit l-smash as well.
  6. With 32bit L-smashsource i get this error.
  7. Last edited by sneaker; 4th Feb 2016 at 04:00.
  8. Installing VS C++ 2015 redistributable didn't fix the error. When i used static l-smash build i got this error.
  9. If you can't get it to work, other options are to remux to MKV and use FFMS2 , or DirectShowSource()
  10. https://github.com/FFMS/ffms2/releases <-------- ffms2 2.2 msvc - is this the one which i should use?
  11. Sure try it. FFMS2 is a bit buggy (or at least there are a few builds that are buggy). Most people favor l-smash these days, especially for transport streams
  12. Click image for larger version
    I get one error after the other
  13. Are the file name and path of "C:\Users\xyz\Desktop\00000.m2ts" correct?
    It seems both l-smash and ffms2 plugins are now loaded correctly but they cannot open the file, either because they cannot find it or because they cannot handle this specific file. (i.e. the format is incompatible or the file is broken)
  14. The video files opened in avspmod with ffms2 when i remuxed it to mkv. Should i make any changes to this script for 10bit encoding?, im going to use simple x264 launcher.
    LoadPlugin("C:\Program Files (x86)\AviSynth\plugins\ffms2.dll")
    ffvideosource("C:\Users\Abhijith\Desktop\00000.mkv ")
    Crop(242, 0, -242, -0)
    Spline36Resize(958,720)
    Source is Bluray - Anime.
