Hi there,
For Handbrake 0.10.2, when tweaking the settings, and seeing what settings works best, how do I test only a small section of the file? Is this possible?
I don't want to sit around for three hours of encoding, waiting to see if a certain setting has worked or not.
Thank you!
You can use the "Preview" option which will use your settings to create a clip of a duration of your choosing.
Cut out a small section of your original video file with a lossless cutter?
They that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin
Special combination of one subtitle with a small section of plain text
By Username2013 in forum SubtitleReplies: 2Last Post: 8th Sep 2015, 12:04 -
small frame with movie in the corner of another movie
By cobra1 in forum EditingReplies: 7Last Post: 16th May 2015, 19:09 -
Best video bitrate for a 2 hour movie with small file size?
By JackSpicer0 in forum Newbie / General discussionsReplies: 5Last Post: 20th Feb 2014, 16:47 -
Remove Small Section of Center Channel from Stereo Track
By EmpireStrikesBack198 in forum AudioReplies: 14Last Post: 31st Jul 2011, 13:48 -
Is there a small test video one can use to test Rec 601 / 709 conversion?
By Asterra in forum Video ConversionReplies: 5Last Post: 19th Jun 2011, 09:28
