Recently I bought me a copy of this soft. Unfortunately, they did not warn me,
it was no good on subtitles for Mac version...the leit-motiv of my buying.
I accepted swapping for PC version, much to my desliking...
Now I get nothing when try to run the application...it hangs since start.
I have had several answer from Xili, including sent thru ftp (theirs) copies of
files used...subtitels...etc. and have NEVER gotten an answer.
Is Xilisoft out of business? Broke? Wrong personnel?
What do I do next?
Has anybody got an answer?
Results 1 to 9 of 9
Get your money back,it's a crappy software.
Yep. Use instead handbrake, vidcoder and xmedia recode. All free!
Thanks for the advice...
Unfortunately, NONE works for subtitles
Diokamos -
All three work with subtitles.
You might describe your subtitle problem and someone here should be able to give you information about subtitle usage.
And perhaps attach the subtitle to the post.You might describe your subtitle problem
But why can't you not just have what-ever-player you're using have displaying the subtitle? I guess the reason for re-encoding is to get harcoded subs? -
I sure can, amigo...but:
I need inserted subs to have relatives see the video files in their native language. Simply -
Yes, I have
You cannot change case sizes. The default is too small for my sight
So...
xilisoft video converter problems
By femellechatqueen in forum EditingReplies: 3Last Post: 1st Feb 2014, 18:24 -
Wondershare Video Converter Ultimate vs WonderFox HD Video Converter Factor
By zzzk in forum Video ConversionReplies: 1Last Post: 3rd Jan 2014, 16:25 -
xilisoft video converter ultimate - problem adding file..
By Symbiot in forum Video ConversionReplies: 2Last Post: 9th Apr 2013, 15:51 -
Xilisoft video converter help
By paul278 in forum Video ConversionReplies: 3Last Post: 18th Sep 2011, 05:12 -
By Vman94 in forum Video ConversionReplies: 0Last Post: 12th Jul 2011, 11:35
