I can hear it fine in an actual edit, just not in the preview. All I get there is a harsh, loud noise. I have the AC3Filter installed, and can hear AC3 sound fine in media players, just not in Solveig.
PS I've checked the list of Preview Direct Show Filters. AC3 isn't in there. And I don't know how to get it in there.
Results 1 to 30 of 30
So did I. Well one I muxed with MKVToolNix anyway.
I have ffdshow installed
Yep. This too.
Name: ffdshow Audio Decoder
Version: 1.3.4531.0
Path: C:\Program Files (x86)\ffdshow\ffdshow.ax
I don't know what I'm doing wrong. All I get is a really harsh sound like a drill through the brain. -
I tried this. I thought my version of Solveig was 64-bit so I tried the x64 folder. Right-clicked on the .bat file, selected Run as Administrator, all that happened was a command line window popped up that said installing, then showed a licence agreement which I scrolled down through, and then when I reached the end, the window just vanished. So I assumed it had installed. I tried Solveig with the same video and still got the loud noise. Then I realized Solveig was 32-bit so I tried the x86 folder. This time, instead of a licence agreement, the command line window, after it said installing, said The system cannot find the file specified, and disappeared. Tried Solveig again, again got the loud noise.
Where did you find a 64 bit AC3ACM? Just FYI, you can't install a 32 bit version for use with 64 bit programs. Only 32 bit programs will be able access 32 bit AC3ACM. Even that may require a special installation procedure on 64 bit windows, like the Lame ACM codec:
https://forum.videohelp.com/threads/271712-Lame-MP3-Encoder-on-Vista-x64#1723154
Oh, found a 64 bit version here: http://sourceforge.net/projects/fcchandler/files/Ac3Acm%20Codec/
But the fact that you're hearing "something" probably means it's a decoding problem, not a missing codec.Last edited by jagabo; 1st Feb 2016 at 12:28.
https://www.videohelp.com/download/AC3ACM22.zip has both 32-bit and 64-bit versions.
I just used solveigmm video splitter home edition from http://www.solveigmm.com/download/SolveigMM_Video_Splitter_Home_Edition.exe . Doesn't mention anyting about 64-bit. -
Yeah, when I looked earlier there was no mention of a 64 bit version. I didn't download it and look inside.
Yep. My Solveigmm Video Splitter is 32-bit.
You don't need LAME it's an MP3 codec. It's the installation procedure that's important -- some other 32 ACM codecs can be installed with the same procedure (just change the file names). I would assume the 64 bit version of AC3ACM comes with a setup procedure that works with 64 bit Windows. Maybe you need admin privileges?
Sorry for taking so long to get back. And sorry, I don't know anything about anything. I know nothing about technical anything. So I just need step-by-steps. I can't hear AC3 (or, as I've just found out, DTS) sound in Solveig. I would assume I have admin privileges. It's my own computer and I'm the only one who ever uses it.
When you run the install, instead of just double clicking on the INF or install program, right click on it and select Install/Run As Administrator.
Instead of running the "Install the 64-bit codec.bat" right click on AC3ACM64.INF and select Install.
OK. Did that. A box appeared for a split second that I didn't have time to read before it vanished. I could try it again though. Then the desktop refreshed. Nothing else happened. So I assumed it had installed. I tried loading the problem video into Solveig again and again just got the same old noise.
EDIT: Tried it again and tried reading the box but it just appeared and disappeared too quickly. -
Check: Control Panel -> Programs and Features. Does "AC-3 ACM Codec x64 2.2" show up there? If so, it's installed. If SolveigMM still doesn't produce audio it must not be using the ACM codec.
Is it just this one video that's giving you problems or all videos with AC3 audio?
I don't know anything about SolveigMM so I can't help you directly with that. Does it give any kind of error report? If you make a video with the program does the new video have audio or it silent? Maybe post a full MediaInfo report of your source video. -
Sorry, I lost track of the details. One possible problem I can think of is the number of channels. AC3 can be anywhere from 1.0 to 5.1. If the software isn't prepared to handle the number of channels it might give the symptoms you're hearing.
Get and install 32 bit Solveigmm.
Some other things to try, not necessarily in this order: Disable the AC3 decoder in ffdshow. Any difference? Uninstall AC3 Filter. Any difference? Open one of your videos in GraphStudio. What filter is is using to decompress the AC3? Use a filter manager like FilMerit to change the merit of different AC3 decoders on your system (the filter with the highest merit is preferentially used by DirectShow). Change the output format of the AC3 decoder that's being used. -
What are you talking about? I'm ON 32 bit SolveigMM. There is no other kind.
When you said switch to 32 bit, I had no idea you were talking about Solveig. I'd assumed you'd been keeping track of the thread.
I'll try those other things you suggested anyway.
EDIT: Disabling the AC3 decoder in ffdshow WORKED! THANKS! And I tried the same solution for the DTS problem and that worked too!Last edited by Bruce Wayne; 5th Feb 2016 at 13:36.
SolveigMM Video Splitter 5 release with subtitles and multiple audio
By DmitryV in forum Latest Video NewsReplies: 0Last Post: 22nd Mar 2015, 04:06 -
SolveigMM Video Splitter: frame accuracy not possible
By Freodon in forum EditingReplies: 3Last Post: 24th Jun 2014, 09:32 -
Need help on smart rendering in Solveigmm Video Splitter
By seymoria in forum EditingReplies: 3Last Post: 10th Feb 2014, 17:14 -
SolveigMM Video Splitter 4 release with FLV support
By DmitryV in forum Latest Video NewsReplies: 0Last Post: 31st Jan 2014, 10:50 -
Restoring sound to SolveigMM Video Splitter please?
By MarcMiller in forum Newbie / General discussionsReplies: 5Last Post: 17th May 2013, 13:11
