Hi cats,
please I wornder if the x264vfw encoder can also deinterlace.
For example my extra commandline is:
but I would like also deinterlace using yadif, is this possible? thanksCode:--tff --range tv --colorprim bt709 --transfer bt709 --colormatrix bt709 --keyint 33 --bframes 0 --sar 1:1 --log-level none
Results 1 to 10 of 10
XmediaRecode can De-interlace via Yadif. I sugest you use that instead.
Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Frame serve from your NLE to Virtualdub.. http://www.debugmode.com/frameserver/ Won't cost you anything...
Virtualdub and x264vfw
By GradationAir in forum Video ConversionReplies: 25Last Post: 30th Sep 2014, 04:19 -
using x264vfw as ffmpeg?
By marcorocchini in forum Newbie / General discussionsReplies: 5Last Post: 16th Jul 2014, 08:53 -
x264vfw configuration in VirtualDub- please help
By ofir_a in forum Video ConversionReplies: 10Last Post: 18th Mar 2014, 11:53 -
Need some help with VirtualDub and x264vfw
By Maukr in forum Newbie / General discussionsReplies: 1Last Post: 29th Jul 2012, 08:02 -
x264vfw x64 question
By Danzaemon in forum ProgrammingReplies: 16Last Post: 16th Mar 2012, 15:35
