Should i let the software choose what the screen size should be? I am using Prism video converter. I converted a DVD to .mp4. I wanna play it on a 32 inch HDTV. Thanks!
If you're going to be playing the video on an HDTV, why change the resolution at all? You'll risk taking a hit on quality, and the TV's scalers will probably handle the job better than a converter program.
If cameras add ten pounds, why would people want to eat them? -
Thank you for the suggestion. I will go with what you said. Thanks again!
Problem playing DVD converted from progressive Full HD MP4 on DVD player
By Nyyr in forum Video ConversionReplies: 25Last Post: 25th Apr 2015, 09:32 -
Converted FLV to MP4-Video OK. Now trying...
By adamberkey in forum Video ConversionReplies: 6Last Post: 1st May 2012, 22:41 -
Ideal Size and Resolution HDTV for typical avi/mkv rips?
By Danteism in forum DVB / IPTVReplies: 3Last Post: 25th Nov 2011, 07:51 -
What is a Reasonable Size for a DVD File Converted to AVI or MP4?
By Novice20 in forum Video ConversionReplies: 3Last Post: 23rd Oct 2011, 22:58 -
Should converted .mp4 file be this large?
By brassplyer in forum Video ConversionReplies: 9Last Post: 3rd May 2011, 15:17
