I made a big mistake of installing the kmplayer. I can’t research for hours about something, but when I checked into it I didn’t find people warning and you can always some that have probs so there is no way to know until you try something. I tried to keep it from installing with tons of defaults, but I guess it did anyway. It wasn’t going to do what I wanted and I didn’t particularly like it so I used their procedure to uninstall it. One day I went to play a flv video and wmp wouldn’t play it. I had to change the file association and also reinstall the codec as that was messed up somehow. Just now I had done some recording with OBS and my elgato. I went to play one of those and I see it is now called a kmplayer.ts file and it won’t play. I am taking a look and this garbage has apparently changed all of my video files to kmplayer with various file types. I have no idea how to get these back to what they were so I can play them. It has apparently even got into my elgato program to modify the setting there. I can’t play anything I record using it. I can’t even get onto the km forums as the code sign in won’t work. I have sent a couple emails to the company but who knows when and if they will get back to fix this. I am incensed at this company. An uninstall needs to revert everything back to the way it was. Does anyone know how to fix this problem? Thanks
	Ok, I may be able to fix this without too much trouble. I was looking and there is actually no ts or even mp4 listed in default progs! I was looking at my videos and not all have been changed. Those that weren’t messed with would play in wmp fine. I didn’t want to make things worse but when I clicked a kmplayer.mp4 it on the warning box I could check to select a way to play it. It then selected wmp and that has changed what appears to be all of the mp4’s back to a normal file name. I did the same for the ts files. I guess as I go if any other diff files come up I’ll have to do this again. So apparently I have this fixed. But for anyone that isn’t aware how much these programs can mess up your media files, be warned. If anyone has any ideas anyway send them my way. These companies are just incredible in how they are all great when they are getting their ad revenue, donations etc, but when there is a problem good luck getting help or getting paid back for damage to things. Thanks all.
	Yes, thanks for that. I actually had thought of that in case. I don't know if I would have a restore point though if necessary that would be back far enough. I need to make sure that the restore system is all set up properly as sometimes these problems aren't really found out until some time has passed. I don't always use certain features for a while to know what all has been messed up. It is always such a nice surprise when you go to use something and it's all screwed up. Thanks again for the help. Fred
  kmplayer 3.0.33By snmn_9188 in forum Newbie / General discussionsReplies: 0Last Post: 17th Jul 2012, 12:20
  KMplayer problem: cannot play the .flv and .mp4 filesBy hithit168 in forum Software PlayingReplies: 3Last Post: 13th Jul 2011, 04:01
  Can I save a Video/Audio being played on WMP/VLC/KMPlayer?By ConverterCrazy in forum Newbie / General discussionsReplies: 2Last Post: 12th Jul 2011, 01:27
  KMplayer problemBy hilario in forum Software PlayingReplies: 1Last Post: 22nd Apr 2011, 16:21
  KMplayer errorBy redzero36 in forum Newbie / General discussionsReplies: 9Last Post: 6th Apr 2011, 18:07
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
