Hi everyone.
Im currently recording my game play and i am having an issue. I'm using the following settings; HD1060, 60FPS, Quality between better and best, Decoder DXVA (AMD RADEON HD5450.
Sometimes it records fine and then other times with the same settings i try to open the game play and it says; ERROR 2002 - a bad public movie atom was found in the movie.
What can i do?
Thanks!
It might help if you were to mention what program is giving you this error. Also the movie format >> .mp4 etc.
A quick 'Google' of the entire error message returns many hits but most are several years old and refer to specific programs such as iTunes. Might not be relevant to you. -
Chances are that the frame-rate is screwed - that is what some of the 'Google' results state.
All I can suggest id that you look at those search results and the fixes refered to.
Maybe others have more suggestions.
Did you contact Support at Elgato ?
Elgato HD60 video corruption problem
By akaranzo in forum Capturing and VCRReplies: 0Last Post: 15th Nov 2015, 05:44 -
Streaming problem with ELGATO HD60
By yaston in forum Video Streaming DownloadingReplies: 18Last Post: 14th Nov 2015, 12:43 -
Elgato Game Capture HD60 Problem
By yaston in forum Capturing and VCRReplies: 1Last Post: 12th Nov 2015, 14:57 -
Elgato Game Capture HD60 files
By yaston in forum Capturing and VCRReplies: 10Last Post: 16th Sep 2015, 12:59 -
Is there any way? (Elgato Game Capture HD)
By Vic 2.0 in forum Capturing and VCRReplies: 1Last Post: 12th Jul 2013, 16:49
