Someone wanted me to put their dvd on blu-ray. They want this because they say blu-ray has greater scratch resistance.
I thought I could just drage the TS folders on the bd-r. When that failed I found dvd2bd-express.
That works except now the audio is out of sync. Just slightly.
I wanted to gauge the delay by using VLC, but VLC won't play the disc. Neither will the windows media player.
I burned the disc with ImageBurn. So, do you think it was the dvd conversion process or ImageBurn?
Is there a better way to convert the dvd to a blu-ray disc?
Any constructive advice is welcome.
Thanks.
I'm pretty sure dvd2bd express cause the out of sync.
Try play the biggest m2ts file in BDMV\STREAM folder with VLC and see if you notice any delay on your computer.
But I haven't heard that blu-ray disc has greater scratch resistance? -
You could look into Verbatim scratch resistant media: http://www.amazon.com/Verbatim-4-7GB-Trimcases-VideoGard-Protection/dp/B0007QN19E/ref=...atim+videogard
Correct out of sync sustivles srt files? they fast.
By PedgeJameson in forum Video ConversionReplies: 3Last Post: 2nd Apr 2015, 07:59 -
Solved:possible to automatically correct audio pitch and sync it with video
By Srivas in forum EditingReplies: 2Last Post: 4th Jul 2013, 13:49 -
Re:- sync Audio to Vedio - audio starts in sync but goes out of sync at end
By ABBrittain in forum Newbie / General discussionsReplies: 2Last Post: 22nd May 2013, 12:08 -
How do I correct out of sync audio using Fraps, or avoid it
By Didz in forum Capturing and VCRReplies: 3Last Post: 10th Sep 2011, 12:42 -
how to correct out of sync video/audio in mkv file
By 55trucker in forum Video ConversionReplies: 37Last Post: 22nd Mar 2011, 11:08
