  1. I've been using VLC to record clips from x264 files for a while now without any issues, but when I tried to do the same thing with x265 files, the clip VLC saved had only the audio track, no video frames. I'd like to avoid converting my files, but is there anything I can do/download so I can work around this issue?
    Recording clips? Like cut out clips with the record button/feature?
    You could always try latest vlc media player beta, http://download.videolan.org/testing/2.2.2/macosx/
  3. Yeah, using the record button to save short clips from my files.
    I've tried using the beta version, and it still records only audio, no video. Is there a different app I could use instead?
    I haven't tried cut any x265 video files. But you could try latest avidemux and see if can read them.
  5. Dinosaur Supervisor KarMa's Avatar
    Jul 2015
    US
    Currently the only way I know how to cut HEVC/x265 videos is to use the split option with mkvmerge, which will give me a very approximate cut. Within 10 seconds of what I want, depending on the size of the GOP and where the I-frames are relative to where I want to cut. This works great with closed-GOP encodings, and may cause errors with open-GOP encodings. Obviously this is not a great option, but works when you don't want to re-encode.
