Hi,
Sorry if it is a dumb question but I have used mkvmerger and muxed video and subtitle file to play on my Sony blu ray player(you know why I have to mux.. that's Sony) .. but issue here is I am not able to fast forward my file and if I try to do that video stops. I googled it but unable to find proper solution. Please guide me.
Thanks.
Did that occur without the subtitle ? (did it play and seek normally without the subtitle?) ; Or is the video the underlying problem, an incompatibility with your player ?
In mkvtoolnix GUI's go settings->merge->default values and add the following into "Default additional command line options":
--engage no_cue_duration and --engage no_cue_relative_position --clusters-in-meta-seek
After that open your file again and remux. Then test fast-forward again.
https://github.com/mbunkus/mkvtoolnix/wiki/Improving-playback-compatibility-with-players -
I see another problem now.. I am getting below error.. reinstalled software but I see same issue.. any suggestion plse..
The file 'and' could not be opened for reading: open file error. -
Post the complete command-line you are trying to use. Don't forget to use quotes for file names that have spaces.
work-around for fast forward prohibition
By Raul McCai in forum Newbie / General discussionsReplies: 4Last Post: 20th Jul 2015, 15:17 -
Fast Forward Editing Software
By Liverpool92 in forum EditingReplies: 3Last Post: 21st Dec 2013, 08:59 -
Any way to get a slow rewind/fast forward?
By justin81 in forum RestorationReplies: 1Last Post: 5th Nov 2012, 14:58 -
[MP4] Can't fast forward or rewind
By yetanotherlogin in forum Newbie / General discussionsReplies: 3Last Post: 14th Jun 2012, 10:21 -
AviDemux Fast Forward and Rewind
By MJS in forum EditingReplies: 2Last Post: 2nd Feb 2011, 07:16
