I'm looking for a great workflow that makes it easy and simple to remux mkv to mp4/m4v for adding to iTunes and that also adds in the metadata and thumbnails.
I used to use Subler on the mac, but since virtualising my servers I can't get OSX to run reliably and quickly on the hypervisor so I'm now looking for a replacement workflow on windows - I've googled extensively but there doesn't seem to be a single app that does it all?
Can anyone share their workflow for mkv -> mp4/m4v that adds metadata and thumbnails so my iTunes library still looks great?
Thanks,
Nice! That seems to do exactly what I want - just testing it out now.
Is there any way to batch / queue several files at a time? Can't seem to find any mention of it which would be a shame as I can't sit and wait for them to all finish before getting the next one ready to run... -
Can't you load all mkvs directly and convert? Or do you have to set properties for each mkvs?
Ah - yes you're quite right. Didn't quite grasp the way the UI works.
Thanks for your help.
MkvТоMp4 v0.224 - rapid tool for repack Mkv to Mp4
By oreons in forum Video ConversionReplies: 808Last Post: 7th Mar 2022, 02:43 -
how to edit mp4/mkv metadata in windows?
By mrjayviper in forum Video ConversionReplies: 6Last Post: 30th Jun 2015, 21:13 -
Workflow Suggestions for MP4 & MKV
By fotoAv8r in forum Blu-ray RippingReplies: 4Last Post: 1st Apr 2014, 14:15 -
How to change encoder metadata in mp4
By psycholyzern in forum LinuxReplies: 4Last Post: 11th Jun 2013, 10:46 -
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19
