I am looking to find an editor that can edit the ts files I have easily. Using Media Info, it tells me my video stream is AVC, the audio stream is AAC, and the text stream is EIA-608
This is my first venture into TS files. What I have been doing with other recordings is keeping one master copy of the original recording, one direct stream edited copy (keeping in case I need it if to do a new burn) , a converted copy from the direct stream edit for Apple TV/IPAD, and a converted copy into .m2ts format before inputting that into a program for burning into bluray (I've been using TMPGEnc Authoring Works for burning to bluray). For the direct stream edits without reconverting, I have been using an old version of "Free Video Editor".
Because this is so new to me, I need some guidance as to what I should be using to accomplish the same (if possible) with these ts files. Any suggestions are appreciated. Thanks!
Can't you do any cutting with tmpgenc authoring works?
Or else would would I try Tmpgenc Mpeg editor and Videoredo h264 suite for exact cutting. -
I looked at loading the file into the Authoring Works program. What was interesting to me that the file was showing in 2 second increments within the program making me think that wouldn't work well. Am I wrong on that?
Does Video Redo allow after cutting to basically do a direct stream copy from what is left? -
Newbie here : need some help on editing a video
By megaman119 in forum EditingReplies: 5Last Post: 30th Jan 2016, 18:38 -
Subtitles editing-newbie questions.
By Alvendam in forum SubtitleReplies: 15Last Post: 23rd Jan 2015, 07:30 -
Newbie here looking for Editing Software help
By PointandShootMediaWorks in forum EditingReplies: 3Last Post: 11th Jan 2015, 22:33 -
Need Help - Newbie to video production/editing
By SpeedWerksHD in forum Newbie / General discussionsReplies: 2Last Post: 6th Sep 2014, 14:34 -
i need help editing a avisynth script for newbie
By sam1776 in forum Newbie / General discussionsReplies: 15Last Post: 5th Apr 2014, 00:06
