I'm transforming some Lightwave rendered uncompressed AVIs into MKV in AVS Video Converter using AVC codec, H264. But there's a problem: The last 12 frames are removed from each sequence.
Anyone know a way around this?
Using MPEG4 does not do this, but looks like crap...
Are you sure the frames are missing from the encoded video? Could it be the way you're viewing them isn't displaying the last 12 frames?
Yeah, last half a second is confirmed gone - have checked the converted files out in video editors
What about the source video? Are you sure the frames are there? For example, open the AVI in virtualdub and scrub to the end
If you can see the frames, then probably avs video converter messed up the conversion. Try can something else like staxrip, megui, hybrid, etc...
Issue with H.264/AVC export in Adobe Premiere Pro
By N3SH0m in forum EditingReplies: 26Last Post: 2nd Feb 2015, 16:42 -
What is the difference between AVC High 10 and AVC High?
By lawllmaster in forum Video ConversionReplies: 3Last Post: 29th Mar 2013, 03:29 -
AVC level 5.1 to AVC level 4.1 conversion?
By tomisoft in forum Video ConversionReplies: 4Last Post: 4th Nov 2012, 07:57 -
AVC vs H.264...
By agent154 in forum Video ConversionReplies: 1Last Post: 8th Apr 2012, 02:30 -
AVI or AVC?
By agni451 in forum Video ConversionReplies: 6Last Post: 7th Feb 2011, 02:39
