Please advise on the best current tool to seamlessly (or close as possible) join a series of mkv files made in MKVToolnix under MKVMergeGUI.
I have limited experience with MKVtoolnix.
You can join files in mkvtoolnix using the append button in the main window. Just drag in the first clip, click append and drag in the next. repeat until done. However, If the formats do not match you will have to reencode your files so they do.
mkvtoolsnix doesn't make video(files), it puts already made videos into the mkv container. unless the videos you want to join were originally made together and then split there is a big chance they can't be combined by simply adding them together in mkvmergegui.
use mediainfoxp to check the details of the files. if they don't match then re-encode them all to matching specs.--
Ok. I didn't want this question to get too old before answering.
If all the appends are made with MKVmergeGUI created files then will the appends go smoothly? The container will be the same. But the merge function is used to substitute a processed audio file and one with an edit also.
MKVtoolnix works but I have difficulty with it.
Philips DVP 3000 Series play MKV & X264.
By mreccentric in forum DVD & Blu-ray PlayersReplies: 2Last Post: 8th Nov 2014, 09:18 -
Join multiple series of mpg files?
By Chasden in forum Newbie / General discussionsReplies: 17Last Post: 18th Sep 2014, 06:43 -
Panasonic Viera St50 series media viewer.. inabilty to play some MP4 files
By idreos in forum DVB / IPTVReplies: 6Last Post: 8th Jan 2014, 23:52 -
Join avi files from a series
By loninappleton in forum EditingReplies: 6Last Post: 11th Dec 2013, 15:33 -
how to join mkv.a and mkv.b files
By sumeshkri in forum EditingReplies: 1Last Post: 5th Apr 2012, 20:56
