  1. With any Windows computer I can go to any folder and type in a certain ftp://...m.org
    address and access the corresponding remote ftp folder(see screenshot). I can then upload/download files to that remote folder just by dragging the file from/to the folder window.
    My question is: Is there a way to do this with Android smartphone?
  2. Most browsers support ftp.
  3. Or you could try Ghost Commander if you want more control.
    https://sites.google.com/site/ghostcommander1/
    Jan 2007
    IIRC there are file managers that support this, through send and copy commands
    although "the cloud" is the current hot thing
    but Android does not have drag and drop, unless it has been implemented on tablets with the newest iteration/flavor of android
    not enough screen relestate on phones, to have 2 locations open and finger drag a file from one to the other
  5. Member Cornucopia's Avatar
    For my Android devices, I regularly use "ES File Explorer", which has capability for multi-panel views (swipe-able). This includes a couple of Network views, including SMB/CIFS, FTP, NFS, and various Cloud services (such as Box, DropBox, Drive, etc). It's easy to set up a preset server location and then do "Select+Cut->SwipeView->FolderChoose+Paste" in a matter of seconds.
    I'm sure there are other options out there also (and for iOS as well).
  6. Member Budman1's Avatar
    Jul 2012
    NORTHWEST ILLINOIS, USA
    I use ANYFTP app on my Samsung Galaxy III and it works well, even to my godaddy secure site.
Name:	Screenshot_2016-01-28-22-58-31 405 720.png
ID:	35420Click image for larger version
Name:	Screenshot_2016-01-28-22-58-46 405 720.png
  7. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    I suppose I should ask... jimdagys, are you looking to access FTP sites from your Android phone, or are you wanting to access your Android phone through FTP?
    Feb 2004
    Australia
    Use ftpserver
    handles files to and from
