Hi all,
I'll start by saying that I've read a lot at this point and I'm completely overwhelmed by the amount of information there is. I somewhat have the fundamentals down, but now I'm at a point where I need to ask some questions.
I have 13 video files, 3.39 GB in size totaling 4:35:36 in length. They are 720x480 with an average bit rate of 1800 kbps (audio averages 110 kbps). I'm using DVD Flick to author. With all the files on one disc, DVD Flick marks it as 98% full with a bit rate of 2000 kbps.
My question is this: am I doing myself a disservice by putting all the files on one DVD5, or am I not really losing anything since the bit rate is staying above their bit rate? Am I cutting it too close with the audio/menus factored in?
Results 1 to 9 of 9
You should use 2 discs.
It's not just a question of bitrate but also the codec used. For DVD that's a subset of MPEG-2 which is not very efficient, ie demands high bit rate for good quality. Your source MP4's migth have h.264 which is a much more efficient codec. -
Yes, according to VLC, this is the codec information:
Stream 0
Type: Video
Codec: H264 - MPEG-4 AVC (part 10) (avc1)
Decoded format: Planar 4:2:0 YUV
Stream 1
Type: Audio
Codec: MPEG-AAC (Audio) (mp4a)
So splitting it to two discs, I can average about 4000 kbps. Will I lose quality at this bit rate as compared to 7000 kbps, for example? -
4000 kbps average should give you decent quality.
Sent from my 831C using Tapatalk -
The DVD specs has limitations as to how much bitrate you can use. I usually use 3500 to 4000 kbps average with an 8000 kbps max rate. I think DVD bit rate maxes out at 9500kbps but this also includes audio.
Naturally the more you all tell me, the more questions I have; though these come out of curiosity, as you've answered my original questions!
So really, though the files average 1800 kbps bit rate, it has little to do with the bit rate of the authored DVD? In other words, the DVD having a bit rate double that of the original files still means some quality loss may result? Is that due largely to the difference between H.264 and MPEG-2?Last edited by Much2Learn; 25th Jan 2016 at 21:59.
Yes. Mpeg-2 and h.264 are two different compression methods. H.264 is more efficient, but does not meet the DVD specs.
Bit Depth,Sampling Rate used for Uncompressed Audio-Bit Rate for Compressed
By alexander121 in forum AudioReplies: 9Last Post: 4th Apr 2015, 11:30 -
mp4 bit rate
By tblake in forum Newbie / General discussionsReplies: 1Last Post: 25th Nov 2012, 00:40 -
Overall Bit Rate, Bit Rate with Respect to Quality and Filesize
By kingaddi in forum DVD RippingReplies: 113Last Post: 17th Sep 2012, 22:56 -
What should slide show bit rate and frame rate be in video editor?
By johnharlin in forum Video ConversionReplies: 0Last Post: 11th Sep 2012, 22:00 -
Should the bit rate be the same converting mp4 to vob, and other ?s
By Redeemed in forum Video ConversionReplies: 5Last Post: 22nd Apr 2011, 16:22
