How do I record from an HDMI input to a DVD drive in my notebook?
Not possible
Notebook HDMI is video OUT, not an input
If you have a signal converter and a USB capture device you can record signals at the USB port
If your thinking game play capture
You buy some thing like the elgato..?
HDMI signal passes thru from game box to tv, and a captured signal is recorded to pc
Does not work for capturing Blu ray movies or other hdcp signalsLast edited by theewizard; 24th Jan 2016 at 10:56.
Notebooks have HDMI-out ports to connect the computer with a monitor or TV, but the port can only provide video and audio output. HDMI-out ports can't accept video and audio input.
You would need a USB 2 or USB 3 HDMI capture device to allow the notebook to record video and audio input using an HDMI connection. However, I don't know of any software for HDMI capture devices that allows burning direct to DVD. You would have to record to a hard drive, then burn the DVD later. -
Thanks !
I was unaware that the HDMI is for outgoing information. Will try the USB 2.
muchas gracias
SiriusXM Recording
By CharlieSummers in forum AudioReplies: 1Last Post: 10th Mar 2013, 13:46 -
Some questions about recording
By vsub in forum Capturing and VCRReplies: 6Last Post: 15th Feb 2013, 12:01 -
WTV recording
By hartless in forum Media Center PC / MediaCentersReplies: 9Last Post: 2nd Oct 2012, 21:49 -
Help recording this stream.
By Payers24 in forum Video Streaming DownloadingReplies: 0Last Post: 21st Aug 2012, 20:10 -
TV Recording To PC?
By Rayj00 in forum Newbie / General discussionsReplies: 5Last Post: 9th Aug 2011, 18:13
