I just worte a HUGE letter to you but ******* windows crashed before I got
to send it(.
I aint writing that again so here a brief overview:
pressing a key on the keyboard causes a buzz.
moving the mouse is like holding a key.
when ever the HD comes into use I can hear that working away.
So in brief its like I can hear any inputs my devices make.
I unpluged everything from the back and the constant hum (which I am
guessing now is a fan or a hard drive.) still remained.
Also anything that occurs on screen i can hear that as well. for instance
when I minimise something I can hear it go down.
What my problem aint:
it aint caused by the moniter or any other device, i unpluged them all and
it was still there.
what my problem may be:
A loose connection/broken conection
If anybody had the same or similar problem than e-mail me/ post it on vcd
help.
I have under 3hrs to come up with a solution as I want to capture a film!!
Can you help??
Baker
reboot in safe mode run msconfig, goto startup and turn off everything except systray. check yout autoexec.bat file and make sure everything is ok. remove all cd's from your drives and reboot into normal mode. Also unplug any scanners or printers. Ive also have had a similar problem, that took care of it.
well baker, ive been working on pc's (hardware and software) for over 10 years, my suggestions are not silly, so i don't see where you get off calling them such
for a technical reason to my suggestions, the scanner and printer, more than likely, use dma (direct memory access). If for some reason, the scanner is locked up, the scanner will never give control back to the os, essentially freezing the pc. also, if the cd-rom (which also uses dma transfers) is locked up, then it will never give control back to the system. sometimes when cdrs that were never finished burning are left in the system, the computer will attempt to read this unfinished disc. as a result, the system will hang until that disc is removed. (or the system is rebooted), ive seen this happen on many systems before, just thought i would share this with you.
How to fix audio synch problem in AVI file
By vertical in forum Newbie / General discussionsReplies: 153Last Post: 20th Aug 2021, 07:45 -
Unable to fix audio problem/burn to DVD
By gillyflower in forum Newbie / General discussionsReplies: 1Last Post: 13th Jan 2009, 16:18 -
Problem with Append AVI in VirtualDub - Audio of Sync - How Fix?
By Chakra in forum Newbie / General discussionsReplies: 3Last Post: 6th Aug 2008, 19:00 -
Tool to fix audio pitch problem from DVD?
By haymes in forum EditingReplies: 0Last Post: 29th Nov 2007, 18:15 -
How to fix Audio problem with vcd authoring
By thelotusman in forum Authoring (VCD/SVCD)Replies: 6Last Post: 16th May 2007, 12:20
