Hey guys, I tried searching for the answer on a few different places with no luck. Here is the situation. I have never burned a dvd before but I happened to have a few blank dvd's at my house and my son is here for the weekend. Him and I really enjoy watching "Practical Jokers" It's a tv show. Anyways he asked me if i could make him a dvd of the show so he could take it back to his moms and show his step brother. I have the tv shows downloaded and own a copy of Toast 14. I fired up Toast, picked the beginner or assistant mode and went to dvd. Here is my Problem, I drag and drop the shows I want to put on the dvd and I can only fit THREE tv shows on one dvd?
Why is this happening? The shows themselves are not nearly a gig or larger, however when I drag them in the dvd burn area they show up as 1.3 gigs or so each time. The shows cant be more than 1 or 3 hundred mb's. The length on the shows are all about 20 minutes per episode. I have tried burning AVI and MPEG4 versions of the same show to the dvd and each time the same thing happens. I can only fit 3 shows.
Could somebody please help me out with this? and if this same post is in here please just direct me to it rather than yelling at me for double posting. I did search. I didnt find anything and Id rather spend quality time with my son this weekend than searching on the computer all day. any help would be greatly appreciated.
Thank you very much,
clueless dad
			Closed Thread
				Results 1 to 23 of 23
	The size of the source is not relevant. I guess that the mode selected has a set bitrate which will fit approx. 1 hour on to one disk. So the three episodes is then correct.
 See if there are other modes or you can change the encoding bitrate down from the, probable, 8000 kbps >> 6000 kbps could give you 4 episodes whereas 4000 kbps could give you 6. All assuming 20 mins per episode.
 Just remember that the more episodes the lower the final quality.
	Bruger,
 I guess I could do data files. My son is only six so I wanted to make things as easy as possible for him. But I'm sure he can figure out data files just the same.
 Do,
 I figured since I can get a 2 hour DVD movie from the store that is high quality I would be able to replicate something like that.
 I'll just go with data. Thanks guys.
	Generally not. You'll need a video-DVD for that ie making the DVD using Toast or similar. There are some DVD players that are DivX compatible that can use videos on a data-DVD provided some (strict) specifications are meet.will a standard DVD player be able to read the DVD disk and play the tv shows?
 To use a data-DVD you need a computor.
	I can see that the Sopranos is 13 episodes pr season. Then one disk should have 7 episodes and assuming 40 min/episode that would be a play time of 280 min (4:40). On a DL disk that would be a bit rate of 3.7 Mb/s.How come I can buy say, sopranos season one and it'll be on like two dvd's?
 Using the same bit rate on a SL disk you could have 7 episodes of your show.
	SL: Single layer (DVD-5 4.37 GiB)
 DL: Dual layer (DVD-9 7.95 GiB)
 'the bit rate of my videos
 More precisely: Change the bitrate used on the DVD
 size = playtime * bitrate
 I'm not a mac user and don't know Toast but according to this you can use "Custom" settings and change the averarge bitrate to 3.5 Mb/s which should fit 7 episodes on a DVD-5.
	Well the OP had the info a bout bitrate in reply #2 yet he chose to ignore it or ask for clarification. Does not exactly encourage further contribution in a thread.
 Very few on here use Toast since it is a Mac product but the principles are always the same.
 BTW I have the original Series One of The Sopranos on DVD. And they are on 6 disks (58 mins per episode according to the box). Granted that DL-disks were less common back then but still to fit 3 hours (or more|) on to one reduces quality big time.
 IMO 4000 kbps for video is the 'sweet' point. Go lower at your own disappointment.
	Whist you posted your topic in the appropriate forum as a new user, a moderator can still move it if there is a more appropriate place for it.
 Like I said, Toast is a Mac program and there is a forum for Mac issues. Most Mac users will not go in to PC specific sections.
 But take on a mod as well and you could sure get banned.
	God forbid a moderator then moves you to an area where you're more likely to get good advice regarding your question.
 The answer is to reduce your bitrate with custom settings in toast, DB83 has given you some good general guidelines. Your Sopranos DVDs are dual layer which hold twice as much data and they are encoded using very sophisticated software ($$$$) by experienced technicians ($$$$) often on a scene by scene basis to maintain quality.
	I might get banned from this message board? Let me get down on my knees and beg for forgiveness
 http://youtu.be/Kw6wDsGdrpw
	If you're still around, OP, if you're going to burn DATA to a DVD I suggest using a piece of free software called "Burn."
 burn-osx.sourceforge.net
 Click DATA, and make sure "DVD-UDF" is chosen in the upper right.
 On that note, things got nasty in the thread. Not sure if you want any more help, but if you want to IM me, go ahead. I'll give you my info.
  Optimal Toast DVD settingsBy MikeBintouch in forum MacReplies: 21Last Post: 6th Apr 2015, 11:33
  Burning MKV to DVD with Toast 12 questions....By Reesche in forum MacReplies: 25Last Post: 22nd Dec 2014, 22:28
  How to shrink avi or mpeg files to fit on 1 dvd??By mspowbiz in forum Newbie / General discussionsReplies: 7Last Post: 29th Apr 2014, 07:41
  How to PROPERLY burn DVD2ONE DVD's using TOAST 6.0By galactica in forum MacReplies: 170Last Post: 30th Mar 2012, 03:48
  Apple's DVD-player doesn't seem to get along with Toast DVD-menusBy HitTheRoad in forum MacReplies: 12Last Post: 11th Aug 2011, 04:24
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
