well, i solved my little audio problem, just had to download the older version. Now, how do i handle multiple files on 1 cd. Like Lord of the Rings is 4 files (2 on each CD), what do i do with the source range settings on each 1 and how do i go about maybe combing these files into 1 big mpg. Im reading the guild but it only give instruction on 1 little mpg. I have 4 huge files. Thanx guys
All you need to do is do some calculation and use bbmpeg to split some files. Of course, you have to demux your mpeg files first. Don't know how huge your files are, but that is the idea, which should work perfectly. You don't have to combine files, just split files that are too big.
Multiple AVI Files
By brendan081 in forum ffmpegX general discussionReplies: 5Last Post: 13th May 2011, 03:08 -
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 08:27 -
how do I join multiple avi files with multiple audio tracks?
By helloguys in forum EditingReplies: 1Last Post: 26th Dec 2007, 02:28 -
Multiple AVI's to DVD ????
By paulwilko in forum Authoring (DVD)Replies: 3Last Post: 5th Oct 2007, 04:30 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 12:49
