Hey all,
There is a hockey dad on my son's team that has done some editing of his HD recordings (1920x1080 60i 29.97) and saved them in DNxHD. They look great. He asked me for help encoding this to proper formats. I figure I'd use handbrake, as it has settings for mobile stuff. I noticed that there are no settings for bluray though...some may like a proper disk. Has anybody created a bluray preset for Handbrake?
I looked at: http://www.x264bluray.com/
where they give some x264 settings for bluray compliance.
With handbrake, the audio conversion is easy (LPCM to AC3), as is the burning in of subs if needed (he makes subtitles too). But what about the video?
The page I suggested notes that the following can be used:
Is this even possible with handbrake?1080i29.97 / 1080i30
x264
--bitrate
XXXXX
--preset veryslow --tune film --bluray-compat --vbv-maxrate 40000 --vbv-bufsize 30000 --level 4.1 --keyint 30 --open-gop --slices 4 --tff --colorprim "bt709" --transfer "bt709" --colormatrix "bt709" --sar 1:1 --pass 1 -o out.264
input.file
x264
--bitrate
XXXXX
4.1 --keyint 30 --open-gop --slices 4 --tff --colorprim "bt709" --transfer "bt709" --colormatrix "bt709" --sar 1:1 --pass 2 -o out.264
input.file
thanks
'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
MeGUI is free to use, and it uses X264 like most of the rest of the free encoding programs. It is not very simple to use and the interface is annoying, but it will work with the settings you've listed. I normally only use MeGUI when I want raw .h264 video. MeGUI uses AviSynth scripts.
If you are comfortable with Handbrake, you can probably just add the parameters you want in the Advanced tab, x264 encoder options box.
Sony BDP S1500 bluray player does not play .MKV file or burned bluray DVD
By theguy22 in forum Newbie / General discussionsReplies: 4Last Post: 28th Dec 2015, 18:10 -
How i can encode audio of "REMUX" to "BluRay.720p.DTS" wit handbrake?
By VideoHelp4Ever in forum Blu-ray RippingReplies: 1Last Post: 2nd Jul 2015, 12:41 -
Free bluray converter to h.265(convert your 25GB bluray film to just 500mb)
By david55 in forum Video ConversionReplies: 3Last Post: 4th Nov 2014, 12:15 -
How to shrink a 50GB-BLURAY-movie to fit on a 25GB-BLURAY disc ?
By kulmagen in forum DVD RippingReplies: 31Last Post: 1st Feb 2012, 14:39 -
True PAL 1080i 25fps Bluray -> native 1080p 24fps Bluray?
By BilboFett in forum Blu-ray RippingReplies: 1Last Post: 27th Feb 2011, 12:29
