Hello everybody,
I have this problems. I can't compress a whole tape using DIVX.
I would be grateful if you can point the right references.
First what I did was to capture a long play tape. It turn out to be around 19Gb. So this file I open in the VirtualDub and I select the compression as DIVX where I selected the 1 pass and I ran it.
The resulted file I droped and use the log and bin file and I ran the second time(2pass). The projected file had 1Gb. At the very first sight I said to myself - great! But wasn't that great.
When I tried to play the file it didn't work. I opened in VirtualDUB and I wanted to see the info. The file looked okay from those statistics but when I tried to play it - only the sound came up.
What do you suggest, what's the best approach ? I want to "transfer" all my recorded tapes to CDs but I don't know what's the best way of doing it.
Please let me know how to do a better job!
Thanks!
Regards,
MCM
Results 1 to 1 of 1
