Hi
I recently purchased a cheap capture card and while the card is working great with its bundled software, I need to open it up in VLC but no matter what I have tried within the VLC app it fails to open
I have tried the "AVerMedia LGP Stream Engine" and selected this in VLC with the Directshow option but keep getting a error the the source is incorrectly setup
has anybody any pointers on how to get VLC to open my captured stream?
oh I can open it with VLC if I put the following in a cmd prompt with FFMPEG
ffmpeg -f dshow -video_size 1280x720 -rtbufsize 702000k -framerate 60 -i video="Video Capture Device":audio="Video Capture Device" -r 30 -threads 4 -vcodec libx264 -crf 0 -preset ultrafast -f mpegts "udp://local IP:6666"
Then open VLC and choose network stream and enter udp://@127.0.0.1:6666
Results 1 to 9 of 9
Latest VLC Media Player? You can also try latest beta version 2.2.2.
And be sure to use VLC Media player 32-bit version. -
Thanks, but when I goto the AVerMedia page and select my device I only get the option to download Stream Engine v1.3.0.13
http://gamerzone.avermedia.com/support/download/live_gamer_hd_lite
where can I find this "LGHD Stream Engine" utility?
strange that the the card works with OBS choosing "LGP Stream engine" -
Here mate: C985_stream_engine_v1.3.0.13_160114.zip
Claudio -
thanks alot Claudio, I will try this when I get home this evening and let you know how I get on
Regards -
you are some man Claudio, thanks for your help
its working perfectly, may you get your Virgins in Heaven
[AVerMedia News] Avermedia RECentral HDCP Protect Remove!!!
By Cauptain in forum Capturing and VCRReplies: 222Last Post: 10th Dec 2025, 12:12 -
AVermedia Capture HD - Playstation
By kurtangle in forum Capturing and VCRReplies: 2Last Post: 14th Dec 2013, 21:03 -
Parameter movie capture with AVerMedia
By Helloyou in forum Capturing and VCRReplies: 23Last Post: 22nd Mar 2013, 08:47 -
Where is the Avermedia Game Capture HD 3.0.6 firmware?
By stranno in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2012, 06:55 -
Avermedia capture HD using firewire?
By Zachash in forum Capturing and VCRReplies: 3Last Post: 7th Jul 2011, 16:49
