Hello everyone i have an issue , i want to extract movie clip and the movie is muxed with subtitle and properly synchronized i use vlc record button and extract my desire part but problem is the extracted part is not sync with subtitle....
Is there any software i extract my desire part with proper sync subtitle and automatically subtitle show instead of use enable button
Here Sample of extract clip [Note:Enable subtitle option]
http://www75.zippyshare.com/v/AZ5P5x4M/file.html
Try cut your clip with MKvmergegui or Mymp4boxgui. They have no preview but you can type in time codes.
If they fail you could hardcode/burnin the subs first. With for example VidCoder or Handbrake. Then cut out the video.
Extracting a subtitle from a DVD used in another region
By pirgah in forum SubtitleReplies: 3Last Post: 31st May 2015, 05:40 -
extracting subtitle file from MKV
By MikeBintouch in forum MacReplies: 4Last Post: 6th Jan 2015, 09:51 -
Video clip name - 5 seconds in start - subtitle
By pcspeak in forum EditingReplies: 0Last Post: 19th Dec 2014, 17:02 -
Subtitle extracting problem with MKV
By PonyoBellanote in forum Video ConversionReplies: 8Last Post: 20th Dec 2013, 06:48 -
Edit SSA subtitle inside MKV files without extracting and remuxing it back
By Solid One in forum SubtitleReplies: 1Last Post: 26th Aug 2013, 10:01
