Hi
I recently purchased a sony bdp s6500 - great player.
But I took it to the uk (as I work there several months a year), but could not access UK apps.
I want to keep my US region setting, so I can play my DVD's and Blurays from here when I am over there. But I would like to be able to watch UK catchup TV when I am there.
Is there a way to install iPlayer, or to tell my system it is in the UK?
I had assumed when I plugged it into a UK network it would pick up UK apps - but this is not the case.
Is there a hidden menu I can change my location on?
All help grateful accepted
(I have been doing google searches all night - can't seem to find this info)
Thanx
Can't you download/add any apps from the blu-ray player menu?
Or else just get a Chromecast and you can stream anything from your computer, android or ios to your TV. Much easier than playing around with a blu-ray player....
You could not change your Region Coding any way. You have a Sony
I guess that 'APPs' are stored in firmware. Try changing that for a US machine in the UK and you might brick it
Don't you have a laptop ? -
the only apps I can see are the US ones. - So can't download BBC iPlayer.
I do have a laptop and a chromecast, but it would be nice to just have a single media player that does what I need - kinda why I bought this device. -
When I said 'stored' I really meant 'built-in'. Nothing to download. BBC I-player is generally available (for UK isp's) from the BBC Website.
Would not be available elsewhere since it is UK licence-fee holders that pay for it. So it follows that I-player would only be available for a UK-targeted player. Guess that Sony pays the BBC for that privilege.
I just checked and the UK version of your player does indeed have I-player and the other usual suspects. -
Sony typically doesn't use a model in multiple regions. Copyrights are different in various regions. And supporting the same player in multiple regions is what makes them hackable.
Get another player or just a simple media player. Either option is fairly cheap and you won't be doing anything that could brick the player.Google is your Friend
Sony BDP S1500 bluray player does not play .MKV file or burned bluray DVD
By theguy22 in forum Newbie / General discussionsReplies: 4Last Post: 28th Dec 2015, 18:10 -
BD-H6500 Bluray Apps Problem
By njb52 in forum DVD & Blu-ray PlayersReplies: 0Last Post: 30th Aug 2015, 11:06 -
subtitles for Sony bluray
By pooka in forum DVD & Blu-ray PlayersReplies: 1Last Post: 10th Aug 2015, 22:12 -
Do any sony 3d bluray players handle sbs material?
By yoda313 in forum Off topicReplies: 5Last Post: 30th May 2014, 17:35 -
Need help making 3D bluray with Sony Vegas 11
By Ivo1977 in forum EditingReplies: 0Last Post: 2nd Mar 2012, 03:52
