    Feb 2010
    Lithuania
    I need an installer of x265 encoder. After installation i want the encoder to appear in my Virtual Dub video compression options, just like it was done with xvid, divx, ffdshow and x264 encoders.
    Is there a link to download x265 like it was with x264?:
    http://sourceforge.net/projects/x264vfw/
    I don't need any "friendly internet encoder" - after installation it does not appear in my Vdub otpions.
    If there is not any installation package, perhaps there are separate dll files and someone can guide me where to put them so that in my Virtual Dub video compression options i could see "x265".
    Sep 2012
    Australia
    All I had to do was click on the link you gave and read the first comment.
    http://sourceforge.net/p/x264vfw/discussion/770224/thread/3e07f7b5/
    Feb 2010
    Lithuania
    Thank you, but it does not appear in the Virtual Dub options, even though it's the same kind of installer as x264...
    Do you have virtualdub 64bit version? If so try virtualdub 32bit.
    You can also PM/ask the mpxplay developer, see last post here: https://forum.videohelp.com/threads/361092-Are-there-any-programmer-who-can-create-vfw-...=1#post2428424
