I recorded something with Snagit. It is only half the length given here as i left it recording after it finished. It is very choppy and i cannot understand how the frame rate is given as 1.256 fps. Can I change the frame rate
General
Complete name : H:\******.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 166 MiB
Duration : 2h 25mn
Overall bit rate : 160 Kbps
Video
Format : AVC
Format profile : Baseline@L4
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=5
Codec ID : avc1
Duration : 2h 25mn
Source duration : 2h 27mn
Bit rate : 62.2 Kbps
Width : 1 196 pixels
Height : 626 pixels
Display aspect ratio : 1.911
Frame rate : 1.256 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.066
Stream size : 64.6 MiB (39%)
Source stream size : 64.7 MiB (39%)
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 2h 25mn
Bit rate mode : Constant
Bit rate : 96.0 Kbps
Channel(s) : 1 channel
Channel positions : Front: C
Sampling rate : 44.1 KHz
Compression mode : Lossy
Stream size : 99.5 MiB (60%)
Results 1 to 15 of 15
Then you didn't do it right. Demux the video stream then mux it into an MP4 with MP4Muxer. Before saving set the frame rate to whatever you want, 30, 50, 60... (you can type values in as well as using the pulldown). Save to a new file.
I cannot see how to work that program. Where to load the video. It will not drag across. I get please select elementary stream to multiplex when i click multiplex. Last night I was able to get a h264 and an aac file using this program as far as i recall
I have tried reencoding to mpeg4 at 30fps with HandBrake and media info says 30fps but it is still jerky and the quality is very bad. Snagit only records at 15 fps. So does that mean it cannot be changed? It was recorded from thew screen with snagit 11
I tried loading into vegas but there is no video only sound. I googled https://www.youtube.com/watch?v=IIJQ6cX7deE said i should get FFDSHOW codec. Is that a safe codec?Last edited by Anonymous; 20th Jan 2016 at 08:04.
Press the Add button. Select an h.264 stream. Optionally select your aac stream. Highlight the h.264 stream at the top then set the frame rate below. Press the Browse button to set the output path/filename. Press the Multiplex button to save the result.
Of course. Handbrake changes frame rate by duplicating or discarding frames to maintain the running time. So if your source is 1.256 fps like the MediaInfo report states, and you convert to 30 fps, each frame is repeated ~24 times. It will play jerky just like the original source. Flagging a different frame rate with Mp4Muxer will result in a video that plays ~24x faster and reduce the run time to 1/24 the original. Audio will no longer be in sync.
I don't know anything about the program but the MediaInfo report you posted says the frame rate is 1.256 fps, not 15 fps. -
OK thanks.
the MediaInfo report you posted says the frame rate is 1.256 fps -
You can speed up the display of the exiting frames or you can duplicate the frames to make 30 fps. The other possibility is to use motion interpolation to create new frames between the existing frames. That works well for panning shots and simple motions, not well for more complex material. You can do it for free in AviSynth but it has a very steep learning curve. All the commercial editors have the feature too, though you may have to pay for a plugin.
It means every frame is to be displayed for 1/1.256 seconds, about 796 milliseconds. -
snagit is set to capture at 15 fps but apparentlty adjusts this depending on input. I just tested another and snagit gave me 10 fps. I don't think it is my computer as Camtasia, which I should have used, records fine.
I tested again and got 9 fps from snagit jerky. Camtasia 30 fps fine
Thanks for your helpLast edited by Anonymous; 20th Jan 2016 at 10:57.
Frame Blend Frame Rate Conversion with Scene Change Detection
By ndjamena in forum RestorationReplies: 7Last Post: 3rd Nov 2015, 09:26 -
How to find out frame exposure time in a variable frame rate .mov file...
By bananas100 in forum EditingReplies: 5Last Post: 24th Oct 2014, 19:18 -
Buying advice on camcorder that can playback frame by frame slow motion
By idkwia in forum Portable VideoReplies: 1Last Post: 9th Jan 2014, 16:45 -
What should slide show bit rate and frame rate be in video editor?
By johnharlin in forum Video ConversionReplies: 0Last Post: 11th Sep 2012, 21:00 -
MediaInfo: Frame Rate vs Original Frame Rate
By adalect in forum Video ConversionReplies: 1Last Post: 19th Aug 2012, 17:44
